Sponsored by: Real Truck
SD wiring
Old Jun 13, 2023 | 04:37 PM
wgb's Avatar
wgb
SD wiring
We have three 6L Super Duties in the family '04-'06. Each has three wires on the upper side of the fire wall by the driver side hood hinge. The colors are red, yellow, dark blue, and black. Can anyone tell me what option these wires are for? They have no terminations on them.
Old Jun 14, 2023 | 06:16 AM
99powerstrokedF250's Avatar
99powerstrokedF250
If these are the 'capped off' wires (they should have little rubber pieces over the ends of them), then they're the firewall pass-thru wires that Ford put in all Super Duties. They're meant to help you install front-end accessories (winch, plow, extra lights, etc.) without having to drill through your firewall. If you look under the dash you should find the other ends of those wires capped off and tied together somewhere - it's been a hot minute since I've had that gen of truck so I don't remember exactly where.
My '99, '03, and '04 all had those wires. They'd been used on the '99 before I bought it.
Old Jun 14, 2023 | 06:55 PM
Edd505's Avatar
Edd505
Not sure about all SD's but my 2015 had them from the up fitter switches under the hood and under the dash. I wired my transfer tank pump to the 30amp switch.
Td63
Sep 20, 2020 08:41 PM
Vince79vette
Nov 18, 2013 03:13 PM
06SD250
Oct 10, 2010 05:17 PM
jonsk
Sep 1, 2008 08:42 PM
XxfirmanxX
Electrical Systems/Wiring
Dec 5, 2004 07:39 AM
