shift cable fix
Old Jun 5, 2023 | 12:28 PM
Tony Ricci's Avatar
Tony Ricci
shift cable fix
I have a 96 f25 that I replaced the steering column and in doing so I broke the f@#$ing clip under the dash.....woo hoo.......any ideas on how to fix it instead of buying while new one
Old Jun 5, 2023 | 01:48 PM
jas88's Avatar
jas88
The clip under the dash - could you be more specific about which clip you are referring to?
Old Jun 6, 2023 | 10:36 AM
manicmechanic007's Avatar
manicmechanic007
If you are referring to the clip that holds the shift cable to the bracket
The one with the little hole that must be poked to remove the cable
You can use a wire tie to hold the cable up and in the slot
Snip off the rest of the broken clip and put the wire tie through the hole
hienergy557
Nov 17, 2015 09:35 PM
Keepitrunnin
Feb 9, 2015 08:02 PM
dadibones
Dec 18, 2005 07:46 PM
johare
1983 - 2012 Ranger & B-Series
Jun 7, 2005 01:32 PM
tbird46
Aug 11, 2003 08:39 AM
