1988 TPS...maybe????
1. The truck starts and runs but the idle is not quite right and the engine will stall if placed in D or R.
2. The engine and trans has been rebuilt and all sensors have been replaced with new Mortorcraft parts in an effort to circumvent the very issue I am dealing with now. The engine has new injectors, plugs, fuel pumps, filters and has been timed according to Ford procuders.
3. I used an OBD1 tester and got a 63 c code which the manual says: Throttle Position (TP) circuit fault, below min voltage.
4. Using my Fluke meter, I tested Primary voltage wire, which in my case is a Tan wire that may have a white stripe. This tested at 4,97V KOEO that is within specs. The secondary voltage (Green wire) was about .43V and did not change as I manually moved the throttle thru it's full range of motion. I repeated this test several times with same results.
5. I checked the 3rd wire for ground ( Black wire with White stripe) continuity back to the negative battery post and it was solid.
6. I thought I may as well check for "Continuity" between the Green wire and ground....nothing. and I got the same results between the Green wire and Black wire.
I'm probably going to get another TPS and see if the TPS was defective. I don't suspect that is the problem. I thought it "might" be the computer; however, I would like to get some second and third opinions before I start digging a deeper hole.
Thanks in advance!
Dying when being placed in drive or reverse, sounds like a transmission sensor related issues to me, but I don't know automatic transmissions so someone else will have to chime in on that.
How does your throttle plate adjustment screw look? A previous owner could have moved it, mistaking it for an idle adjustment screw. The idle air control valve is what actually adjusts the idle.
I replaced the 302 in my F-150 with a 351 and reused all the old sensors and sending units. No need to “fix” something that isn’t broken.
Your response may be spot on. I remember having some some issues trying to install the TPS. I already had the engine/trans installed in the engine bay when I installed the intake manifold and throttlebody which limited access and visibility. When you suggested the TPS should be installed and rotated slightly to algn the screw holes would apply a certain degree of engagement and preload on the TPS that should increase the return voltage AND idle speed. In addition, the correct engagement would li increase the voltage reading when the throttle is moved ny hand thru its' operating range.
Thanks for the insight. I will try this first thing in the morning. In additon, thanks to all those that took the time to review my problems and respond.
I started the engine which sounded like other F150s I have been around (my first F150) and I was able to put the trans in D,R without it stalling. YIPPEE!! Apparently, my Super Power is the ability to install something incorrectly. Anyway, my thanks to My4Fordtrucks and Soup Bean.
