TPS Backwards
Old Feb 1, 2018 | 09:35 AM
Mark Twain's Avatar
Mark Twain
TPS Backwards
Hey all,
I've gotten alot of great help here before, not I have a new issue. I replaced my TPS on the new throttle body and am having issues calibrating this sensor. it is to my understanding that the TPS needs to be at ~0.95v at idle and ~4.6 at WOT. I'm not sure if this is accurate or not, but when I as doing my calibration, the readings were coming out backwards. At WOT, I was low and at idle I was high. Any help would be greatly appreciated.
Old Feb 1, 2018 | 09:37 AM
mark1986F150's Avatar
mark1986F150
Make sure you're measuring resistance across the correct wires...
I've attached a PDF showing how to test it, credit for the document goes to subford.
Old Feb 1, 2018 | 09:53 AM
Mark Twain's Avatar
Mark Twain
Mark, Thank you for that document. I was measuring the resistance correctly. Red is the 5v wire, green is ground, and black is signal. I back probed the red wire and the green wire to measure this voltage.
Old Feb 1, 2018 | 10:03 AM
mark1986F150
Sorry, I meant voltage not resistance. Need more coffee.
Just to be clear, you should measure voltage between TP and SIG_RTN.
Old Feb 1, 2018 | 11:28 AM
Mark Twain's Avatar
Mark Twain
so, to dumb it down to my level back probe the black signal wire on the sensor to my black wire on my multimeter and the red voltage wire on the sensor to the red wire on my multimeter, and do not back probe the green ground wire on the sensor?
Old Feb 1, 2018 | 11:50 AM
mark1986F150
I'm not sure which TPS plug you have, but if you look in the PDF from earlier you can see which wire is TP and which is SIG_RTN. The plug has little details that will help you orient it to determine which wire is which. I also don't see the colors you've described on the wire diagram for 92-95... is your truck an 87 - 91?
At any rate, if probing red + green gives you backwards (high/closed low/open) measurements, I'd wager that red + black will give you the correct measurements (low/closed high/open).
It also doesn't matter which multimeter probe you use to backprobe... all that does is make your voltage measurement positive or negative but in this case that doesn't mean anything. All you need is the magnitude (numerical value without the sign).
Old Feb 1, 2018 | 12:00 PM
Mark Twain's Avatar
Mark Twain
Mark, I have a 1993 F250 351W. The TPS looks exactly like the one in the document. I have the electrical and vacuum troubleshooting manual for the truck too. it describes these wires in it. I'll see what happens when I back probe the signal wire and see what happens. Stand by - and thank you for your help!
Old Feb 2, 2018 | 12:13 PM
Mark Twain's Avatar
Mark Twain
Mark,
I ran the test procedure and was able to "kind of" calibrate the TPS. HOWEVER, what I did was ground the multi-meter directly to the battery and probed the green wire (by all account this is the ground wire). I'm beginning ot think that this sensor is not wired properly direct from the manufacturer. I should be reading the redish/orangeish wire. Thoughts?
Old Feb 2, 2018 | 12:52 PM
rla2005's Avatar
rla2005
There is no calibration required for the TPS. Anything between 06 to 1.0V is within specification. Try to adjust it to a certain value is pointless. It's an urban myth to adjust it in that manner on these trucks.
If you have a Motorocraft TPS the wire colors and functions are here:
Motorcraft TPS Wire Colors
VREF - Orange
TP SIG - Green (TP=Throttle Position SIG=Signal)
SIG RTN - Black
Old Feb 2, 2018 | 01:56 PM
mark1986F150
You don't have to calibrate it... just put it on and plug it in. The only "calibration" per se would be clocking it if you've messed with the throttle stop screw -- even then it would most likely still be in range.
You do not test the TPS output against ground -- the circuit is NOT a grounded circuit in ways that matter to you. The computer reads the voltage differential between TP_SIG and SIG_RTN and both of those have voltage on them. You must test TPS signal by measuring voltage between TP_SIG and SIG_RTN.
It is highly unlikely that it came backwards from the manufacturer.
Have you tried running the truck with the new sensor? That's what I would do.
Old Feb 2, 2018 | 03:15 PM
Mark Twain's Avatar
Mark Twain
Gents, I believe I am tracking. The simple fix to the low voltage would have been to adjust the idle screw on the top of the throttle body? I bought a newer, bigger throttle body and the screw was all the way closed. However, I did crank the truck and noticed an imediate improvement at the startup - no more sputtering.
FYI: This issue was only a small part of the overall wiring harness issues I was having. Other EEC-IV codes I have pulled are 114 (ACT), 116 (ECT), 327 (EVP), 565 (CANP), 636 (Trans Oil Temp sensor). :|
Old Feb 2, 2018 | 03:35 PM
rla2005's Avatar
rla2005
Absolutely not. That is not an idle adjustment screw. It's a throttle stop screw designed to prevent the blades from closing too far in the bore and sticking closed.
I assume this is aftermarket? The the above may not pertain, but on an EFI engine there is no idle adjustment screw. That is done by the computer. Consult the manufacturer's documentation.
Codes 114, 116 and 636 are typically triggered if you did not warm up the vehicle sufficiently before running the tests.
Old Feb 2, 2018 | 06:44 PM
My4Fordtrucks's Avatar
My4Fordtrucks
Am I correct in assuming that you purchased a new BBK throttle body? Did you read the installation instructions?
Old Feb 5, 2018 | 12:27 PM
Mark Twain's Avatar
Mark Twain
Thank you for posting those BBK directions. Looks like my ignorance got in the way of my reading comprehension and I followed them up until Step 8 - I was too eager to find out what power changes the 61mm TB would add to my first engine rebuild. I'll do this tonight with hopes that it will solve the issue. You know, sometimes the most obvious solutions are those right in front of us. Thanks for the reminder!
As far as how the TPS is doing now - it seems to have fixed a few issues. The truck is no longer throwing the voltage code and I'm running much leaner now whereas before I was driving to and from the store, and coming home smelling like a gas can.
Old Feb 5, 2018 | 03:33 PM
My4Fordtrucks
How much power above stock did you go? Wondering why you went with the twin 61 as opposed to the twin 56? I put the twin 61 on my 392. I had a shop gasket match the Edelbrock upper to match the larger throttle body.
