Sponsored by: Real Truck
Power Window Help Needed
Old Nov 18, 2003 | 11:45 AM
dally1up's Avatar
dally1up
Driver side power window in my 2000 F250SD is now completely gone. After months of stalling out midway up and intermittent problems the window will not roll down at all. Passenger works fine.
Is this the motor problem, a relay or what? Any help on fixing the problem would be appreciated as I will try and do this mysyelf as my power door lock is going out too (probably an actuator?). Thanks for any help you give.
Old Nov 18, 2003 | 02:53 PM
dadsgreenpsd's Avatar
dadsgreenpsd
can you hear the relays click under the dash when you push the window button? If so, chances are that the motor is gone. I just went through this with mine, window kept going slower until it stopped halfway up. motor comes out fairly easily, you can check voltage then. mine was full of water (product of a fishing trip gone wrong ). Ex motors fit as well, drivers side front and pass side rear are the same IIRC.
teamlx88
Feb 2, 2014 03:34 PM
bigford8486
2004 - 2008 F150
Nov 4, 2009 10:29 PM
stm250
Oct 19, 2007 09:58 AM
wickware
Sep 15, 2004 02:33 AM
shotgunner426
Oct 3, 2003 04:06 PM
