High mileage 7.3L engines
#121
My guy drove the truck 3 miles to the dealer once the misfires occured, that isn't what clogged the cat, but believe what you want.
Even if it did, shouldn't the certified Ford technician know to look for that? That's my point. Had they found the clogged cat when they should have, I would have just sold, or traded the truck in. get it?
#122
place is full of *******s.
Best of luck with your trucks and that dealer.
#123
#126
#128
I get that same carbon on my 7.3 port injected tail pipe as I did on my 2016 F150 5.0 port injected tail pipe, so it seems normal to me.
#129
The 6.2L is a very reliable platform, but it has a cat problem if you let the plugs go over 100K even with two plugs per cylinder and none of the plug wire issues of the 7.3L. Don't believe me, go on the 6.2L forum and see all the cats that have been replaced because someone ran the plugs too long. Running plugs too long causes misfires and misfires are deffinently harmful to cat longevity. On my 6.2L I changed my plugs wires and boots at 90K so I wouldn't have a cat problem, and I didn't. On my 7.3L I plan on doing the same thing. I also am going to change all the plug wires on my 2022 7.3L at about 30k if Ford got the new D wires right to keep the cats happy.
#130
#131
Received 1,520 Likes
on
Interesting... I thought our '17 6.2 had a clean tail pipe, but perhaps I'm wrong. Sold it to a farmer earlier this year with less than 20k miles of light use. I know my '98 F150 5.4 2V had a clean tail pipe. I ran that truck to ~150k miles and sold it to someone at work who drove it to 250k miles with original cats.
#132
What a tailpipe looks like has so many variables you can't judge by what it looks like and guess what it's running like or health of the motor. Short hopping especially during cold weather will give you a black tailpipe with a wet look same with extended idling. I vehicle that's been run a long distance and had a chance to get good and warm with have a dry cleaner looking pipe. The biggest enemy of your converter is long periods of idle and short drives so it doesn't get a chance to get to it's operating temp, they like to be hot. Back in the day we used to look for a white tailpipe but that was when the fuel still has lead in it now I don't pay much attention to it. A restricted exhaust system can cause all sorts of damage if run that way for a extended period and yes bad plugs will put excess fuel into the cats causing them to plug over time.
Denny
Denny
#133
Denny
Denny
#134
Denny
Denny
#135
If you believe your guy only drove 3 miles with a misfire you are trusting the wrong guy to use your vehicle. just saying
Oh and i guess add me to the list of *******s
The following users liked this post:
