High mileage 7.3L engines
#109
Moral of the story is dont let dealerships experiment with your truck while your pocketbook is paying the bills. None of these dealers are looking inside the engines to verify a failure. A misfire turned into a cam which turned into a whole new engine which turned into a catalytic converter which turned into $21k. You are paying for their incompetence.
We had a conference call yesterday and the mechanics were on it. They said there was never a code that indicated the exhaust was restricted, I told them the spark plugs should have clued them in and they should have dug deeper.
I told them I took the truck to a ford dealer, because I THOUGHT they would know what to look for, instead, I got a huge bill. The plugged Cat caused the cam failure. They had no explanation.
While I have built 2 engines in my time (302 and 460), I am no mechanic and I don't have the time to do the job if I could. I'm not sure what else I could have done here.
The way this went down, made it very difficult to prevent this.
The following users liked this post:
#110
Of course, the service department is going to try to explain it away and it would be a stupid move to pull the truck out and take it somewhere else. I'd end up paying a lot more when all was said and done.
#111
We don't know what caused the failure. It could have been a plugged cat contributing to the misfire and lifter failure or the lifter failure could have been the cause of the misfire and plugged cat or the misfire could have cause the failed lifter and plugged cat. Not enough evidence to chalk it up to poor quality parts. A number of these engines are having plugged cats and we don't know the cause because dealerships don't have competent techs anymore.
#113
Received 1,520 Likes
on
Edit:
So had to look at my wife's 2014 Edge Sport 3.7L with port injection. I know this is a bit of apples vs oranges, but this is what all my gas engines exhaust tips look with ~129k miles. You could almost eat off these chrome tips.
#115
Never gave much thought about it. I'll look tomorrow with 128,500 miles on the truck now. Probably looks about the same as it did in that one pic in the thread.
Edit....
Comparison from10/2021 (top) at 30k miles, today (bottom) at 128,500 miles. Looks normal to me.
Edit....
#116
#117
We have two more 21's. They're at the 75k mark. I definitely need to get the plugs changed out on those soon.
However, I'm not going to blame this on plugs, 5 plugs didn't just all the sudden fail at the same time.
#118
FYI - a misfiring engine is no longer a balanced engine and every moving piece in the engine assembly is negatively affected by an imbalance. Can even push certain parts to the point of failure...
When pointing fingers the lack of spark plug maintenance is putting you front and center for what unfolded down the line with other said failures that can be traced back to a simple misfire condition. Your rant and complaints are no different from the majority of similar posts you see on this forum and they all point to user error first. Take this personally and make a change in your practice instead of playing victim and blaming the product that you didn't follow the maintenance schedule on.
The following 3 users liked this post by OverheadCram:
#119
Not buying it? Why? Because you do not understand what causes a cat to plug? Unburned fuel... from your poorly functioning spark plugs...
#120
Spark plugs left to run out their entire useful life in an engine operating as designed do all fail within the same time frame. Reason why its called preventative maintenance and Ford Lists their recommended change intervals to avoid problems. Ive seen it enough over a career servicing thousands of trucks to date.
I'm paying for a new motor, the mechanics at Ford should have found the clogged CAT, had they told me I had to replace the engine AND the cat, I would have traded the truck in, instead of putting $21k into a truck.with 130k miles. That's the issue here, not what caused what.
