Transmission conversion
Old May 28, 2023 | 10:29 AM
Sferg76F150's Avatar
Sferg76F150
4th Gear
76 f150 with all stock fe390. My project is on hold because nothing happens when it can't move. I have been hunting for an affordable c6 that can handle a little bit of a future power build up, nothing meant to rotate the earth but 5-750ish maybe. Currently it's a complete Ford factory replacement crate 2 barrel that replaced the original motor a very long time ago and received very little use due to a transmission seal leak and was eventually parked. I have made sure the motor stays free, but long story less long.....drive shaft and tail shaft seem to have decided that they are not interested in divorce....the current c6 is likely to never be functional again and if it is find affordable quality repair parts are non existent..... Anyway the question is what is the best options for a conversion with minimal impact on the truck. I wanna roll Ford parts but I keep being told to do a turbo 400 or 700r4. I want daily driveability and it's a truck so I intend to use it like one. PS it's not a race car nor do I want it to be
Old May 28, 2023 | 10:36 AM
bhenders's Avatar
bhenders
Stay with a C6
Any conversion is going to burn up time and money. Always, always run into unexpected issues when installing something where it was not intended. C6 should still be fairly common ? I would search for a top notch transmission shop and have them rebuild your present C6. (Heck, the driveshaft and tailshaft can stay married. Of course you would want to take a good look at all u-joints as part of your project.)
Old May 28, 2023 | 11:12 AM
Sferg76F150
4th Gear
I've been looking
I have been unable to locate any around me that I have any faith in...I found one in a local shop that the guy claimed had been dropped off for rebuild and never paid for, but he couldn't tell me anything about the build not even ratio or valve body setup
Old May 28, 2023 | 11:24 AM
FuzzFace2's Avatar
FuzzFace2
Stay with the C6 it will with stand what ever you throw at it.
As for the trans found ask what it would run to pull it apart to see what is in it before you buy it.
Dave ----
Old May 28, 2023 | 11:53 AM
5851a's Avatar
5851a
Broader Performance How much power you need covered. He is in Texas.
Old May 28, 2023 | 01:01 PM
tbear853's Avatar
tbear853
Truthfully, even 400 hp is overkill for a street truck ... a smooth running 300 hp is about perfect ... but even just 250 hp will do nicely.
Old Jun 3, 2023 | 08:06 PM
mikeo0o0o0's Avatar
mikeo0o0o0
X2 on Broader Performance. He's kinda a one man show but he knows C6's
PA74F250
17
Jan 20, 2011 10:09 AM
jay54f100
Jul 7, 2007 10:33 AM
zeus77
20
Jun 8, 2007 08:31 AM
duckbucket
Feb 16, 2003 12:57 PM
