Changed the MAP sensor today
Old May 29, 2023 | 08:31 AM
  #31
jimzpsd's Avatar
jimzpsd
Originally Posted by Overkill2
Now you're make me go and pull mine because I can't remember if I did that or not... because that sounds like a good idea...
Hahahaha, go ahead and do it.....it's not "Overkill" , but it does make sense.
Old May 29, 2023 | 12:01 PM
  #32
wrvond's Avatar
wrvond
I didn't use a Q-Tip, but I did use an Allen wrench I had handy to ensure the orifice wasn't blocked. I finally went for a short drive (44 miles round trip) and noted an immediate improvement in fuel mileage.
So, I've changed the CCV filter and the MAP sensor. Is there any reason to mess with the MAF sensor?
Old May 30, 2023 | 08:22 AM
  #33
Racinfan83's Avatar
Racinfan83
I pulled mine the other day - as it threw a code. Looked like the ones pictured. Cleaned it with MAF spray cleaner. Worked like a champ. Truck definitely runs better now!
Old May 30, 2023 | 08:35 AM
  #34
aquanaut20's Avatar
aquanaut20
The MAF and MAP are critical sensors for the fuel control, so keeping them in spec is important... Helps if PIDs scanned occasionally..
Old May 30, 2023 | 10:45 AM
  #35
Overkill2's Avatar
Overkill2
I've pulled mine before to clean it and did it again it when I installed my S&B air intake last year.
I can't remember if it was at all dirty or not but I don't think it was...
Old May 30, 2023 | 12:22 PM
  #36
Overkill2's Avatar
Overkill2
Okay so it's been about 19.1k miles since I last cleaned the MAP sensor... Lo and behold, it was dirty again...
I rubbed the carbon off with my index finger to see there's build up inside the hole.. It took 5 Qtips with cleaner to get it clean...
Scrapped the top with a flat screwdriver to get the hard stuff off. I don't remembering doing that last year... Also cleaned out the manifold port with a few soaked Qtips prior to reinstallation.
Only use cleaner rated for sensors...
Old May 30, 2023 | 05:31 PM
  #37
4wd6.7L's Avatar
4wd6.7L
Originally Posted by 4wd6.7L
Funny that you posted this, I was just thinking the exact same thing this morning. The only thing I could come up with is that the hole in the spacer appears to be larger, so it might take longer to clog. Less frequent cleanings could be the advantage. I may send S&B a brief message to see what they say. I haven't been able to find much in the way of user feedback on the forum.
I did send an inquiry to S&B about their spacer. The reply I got was pretty disappointing. Generic, didn't address the question, instead just repeated the line from the part description about reducing soot buildup. I tried asking again, to emphasize my question in regards to build-up on the opening of the spacer itself, and again was given a response having only to do with soot build up on the MAP, not directly addressing my question.
Old May 31, 2023 | 09:31 AM
  #38
q5 dave's Avatar
q5 dave
2016 with 104k. MAP sensor didn't look too bad, who knows if it was ever cleaned but definitely hasn't been cleaned in the 20k miles of my ownership.
Old May 31, 2023 | 09:47 AM
  #39
tradosaurus's Avatar
tradosaurus
Dang it. I guess I will do mine this weekend.
Old May 31, 2023 | 10:21 AM
  #40
FishOnOne's Avatar
FishOnOne
Yeah... Give us a full report
Old May 31, 2023 | 10:49 AM
  #41
scraprat's Avatar
scraprat
Top Answer: 5
This is one of those things that get forgotten about or didn't know about till a thread like this. The forum certainly helps with keeping up to speed on the little details of maintenance.
Old May 31, 2023 | 11:30 AM
  #42
FishOnOne's Avatar
FishOnOne
Ford needs to plumb post DPF exhaust into the EGR and soot build up in the intake tract would be figment of our imagination. C'mon Ford... lets step it up!
Old May 31, 2023 | 12:38 PM
  #43
wrvond's Avatar
wrvond
Figured I'm on a roll, so while I was in town today I stopped and bought a new MAF sensor and a couple spray cans of MAF cleaner. I've got the old MAP sensor I replaced so my plan is to clean it and keep both sensors as ready spares.
So, I was amused to find yet another kind of fastener (two star drive screws) holding the MAF sensor in. Fortunately the plug wasn't as challenging as the plug on the MAP sensor was.
Pulled it out and it looked very clean:
Since I had it apart with a new one in hand, I installed the new one anyway.
While I was in the neighborhood took a peek at the air filter. A few solids on the foam filter and some dirt on the pleated filter, but no need to change it yet.
However, a look inside the airbox revealed a fugitive:
When I set it down to take a picture of it, it became readily apparent where it came from:
Looks like it came loose and was sucked up into the air intake. Hopefully it's fastened more securely this time!
Old May 31, 2023 | 12:49 PM
  #44
Overkill2's Avatar
Overkill2
Me thinks it was cleaned before you bought it but who knows, I could be wrong...
Old May 31, 2023 | 12:50 PM
  #45
Overkill2's Avatar
Overkill2
Exactly right...
