Crankshaft gear
Old May 24, 2023 | 03:37 PM
Larryjr03's Avatar
Larryjr03
Crankshaft gear
1949-53 Flathead V8. I have a pulley puller on the crankshaft gear, it WILL NOT come off ! This is not a junkyard motor either. I purchased a used Merc crank, but the crank was run in a 59AB motor, so I have to change gears. Any ideaa ? I hate to put heat on ,it should come off with a little effort, but DAMN, is it on there ! Thank ya'all. All help appreciated.
Old May 24, 2023 | 06:01 PM
ALBUQ F-1's Avatar
ALBUQ F-1
Heat will do it. Rather than a direct flame, try pouring boiling water over it, and using the puller. Is the key still in it?
Old May 24, 2023 | 07:24 PM
Larryjr03's Avatar
Larryjr03
Negative on the crank key. I will try the minimal heat 1st, then a bit of the Fire Wrench if I have to. Thank you ! Almost ready for the machine shop ! 😊
Old May 25, 2023 | 07:29 PM
Larryjr03's Avatar
Larryjr03
Got gear off, used a Heat Gun. It was more the sleeve than the gear. Previous owner got it out of round. Ready for the machine shop. Thanks again.😊
jkodenski
May 19, 2023 12:05 AM
tony1947
Apr 4, 2010 11:41 PM
ENCSDEI
May 11, 2007 05:06 PM
inliner
May 17, 2002 11:27 AM
