1978 - 1996 Big Bronco
Need 1995 5.0 E40D Transmission Help!
Old Nov 18, 2003 | 07:36 AM
Byter's Avatar
Byter
Hello all,
I have a 1995 Bronco 5.0 with 112,000 miles on it. I was having the common transmission problems that are described in this forum:
Hard shifts, OD light blinking on and off, etc...
First, I had tranny maitenance done. New fluids, filter, etc. It worked fine for a couple of days, but then the same problems occurred again.
Then I had the tranny rebuilt (they did replace the solenoid pack). I can tell the difference in the shifts. If feels more "solid". However, the same problems are ocurring again! Here are the exact symptoms:
1. It seems to mainly occur when I am cruising about 70 MPH. The RPMs will start to increase while my speed decreases.
2. The OD light will begin blinking.
3. The hard shifts occur.
At this point (assuming my tranny was REALLY rebuilt), it has to be a sensor or a PCM problem.
Does this sound familiar?
Do you think its a PSOM problem?
What does the PSOM look like? I think I should replace it...
Any ideas?
I appreciate your help,
Byter
Old Nov 18, 2003 | 09:16 AM
Kemicalburns's Avatar
Kemicalburns
go by any autoparts store and have them pull the codes, if the tranny is having problems it will show up a code. Your ecu may be going out to. check your fluid make sure its full. smell it, if it stinks like rotten eggs you have a problem or if its all bubblie on the dip stick. just because a tranny was just rebuilt doesnt mean it wont fail just as fast. What size tires are you running?
welcome to the show. if you click on settings button at top of page and fill out your signature with specs on your ride it will help us help you and you want have to keep typing what yr, and motor size you have and so on.
late
Old Nov 18, 2003 | 10:26 AM
jimandmandy's Avatar
jimandmandy
Torque converter clutch slippage. The codes will tell for sure. I had the same exact problem. Did they replace the converter?
Jim
Skandalist
18
Jan 23, 2015 09:55 PM
benshere
Aerostar
Apr 2, 2014 05:48 PM
roadblade
Jun 15, 2009 10:11 PM
oregon250
Jul 21, 2003 01:28 PM
oregon250
Jul 20, 2003 10:51 PM
