Ideal Cruising Speed
Old May 23, 2023 | 10:48 AM
NoakeaBean's Avatar
NoakeaBean
I have a '79 F-150 4x4 short bed. Manual 4 speed. 4.9 (300) I6 motor. 3.50 gears. What would be my ideal cruising speed? 50 mph? 55 mph? 60 mph? I'm trying to find the best speed for speed and fuel economy. Thank you!
Old May 23, 2023 | 11:00 AM
Pickupmanx2's Avatar
Pickupmanx2
What is your tire size? My 79 F250/4x/4sp/4.10's w/33's at 55-60 avg. 18mpg when I drove it to MO, my 66 F100/2wd/3.70's and 265/70/15's avgs 16-18 at 55-60, I would have to go drive it to see what my rpm's are, but I believe around 2300... I have found on all of my older rigs, they like 55-60 for best mileage.
Old May 23, 2023 | 11:01 AM
NoakeaBean's Avatar
NoakeaBean
I've got 31 x 10.50 BFG AllTerrain tires
Old May 23, 2023 | 11:24 AM
85e150's Avatar
85e150
Which 4 speed do you have?
Granny 1st? Or OD 4TH?
NoakeaBean's Avatar
NoakeaBean
Granny 1st
Old May 23, 2023 | 01:06 PM
beardedcap's Avatar
beardedcap
My f100 with a NP435/3.55 rear and ~32.7" buckshots will do 60-65 at 2200-2300 RPM. To me that's a pretty happy cruising RPM for not having OD. Shooting for 2000 RPM would probably be ideal for MPG and still having some acceleration but a stock 300 at that speed on the highway may be gutless. Although I find 18 MPG to be hard to believe with any stockish engine in these trucks
Old May 23, 2023 | 01:11 PM
NoakeaBean's Avatar
NoakeaBean
Originally Posted by beardedcap
My f100 with a NP435/3.55 rear and ~32.7" buckshots will do 60-65 at 2200-2300 RPM. To me that's a pretty happy cruising RPM for not having OD. Shooting for 2000 RPM would probably be ideal for MPG and still having some acceleration. Although I find 18 MPG to be hard to believe with any stockish engine in these trucks
is that the same transmission I have too?
Old May 23, 2023 | 01:21 PM
Pickupmanx2
Yes, more than likely, the other option was the T18 I think, my 18mpg avg while driving 1800+ miles was in 79 F250/4x/NP435/4.10's/33's, I also had an Offy 4bbl intake and Holley 390cfm carb, EFI exhausts y-pipe into 2 1/4" glasspack out the rear. My current 66 had the og 240/1bbl/T19/3.70's and 265/70/15's and it avgs 16-18, yes, both gps verified, my other 66 F250 I had was pretty much 16, of course the faster you go, the worse my mileage was..
Old May 23, 2023 | 01:22 PM
85e150's Avatar
85e150
Probably. NP435 is a low 1st /direct 4th transmission
Old May 23, 2023 | 01:26 PM
beardedcap's Avatar
beardedcap
You'll have a NP435 or Borg Warner T18, but it won't make a difference in 4th
Old May 24, 2023 | 08:37 AM
speedfreak78's Avatar
speedfreak78
Fuel economy comes from the lowest RPM you can run the engine without lugging it when you accelerate easily. It has nothing to do with speed. A quick search shows a stock 4.9 has peak torque around 1600RPM, so you'd want to be a few hundred RPM lower, at whatever speed you're cruising at. Ideally you want to be at an RPM where there's just enough torque to maintain speed and accelerate smoothly under part throttle, if you need to accelerate quickly you can downshift.
Taller tires will lower your RPM at a given speed, but will make acceleration slower. It's essentially the same as going from a 3.50 rear gear to a 3.30, or 3.00, depending on how tall you go. My truck with 4.10s and a 34.5" tire was just about the same rpm as 3.55's and stock sized tires. Just don't put on substantially heavier, or wider, tires and don't change your driving habits to make up for the lost acceleration, or you could end up with worse fuel economy.
Old May 24, 2023 | 09:18 AM
beardedcap's Avatar
beardedcap
Having owned an EFI 4.9 truck before with a tall rear end, a straight 6 is miserable on the highway at 1600 RPM. You wouldn't be able to climb a grade without losing speed. I think peak torque is closer to 2000 RPM but it makes like maybe 100 HP there.
Old May 24, 2023 | 09:46 AM
tbear853's Avatar
tbear853
3.50 gearing, 31" tires, 351M, Automatic.
When traveling on a Interstate even with a 70 mph posted limit, my '77 likes 63 mph or less. When the limit was 55, it run 55 or less.
Fordtothemoon
May 31, 2021 09:58 AM
Red Mills
Nov 30, 2020 10:54 PM
Jonesy0027
2015 - 2020 F150
Feb 18, 2018 11:13 AM
FoMoColover
Feb 4, 2007 08:19 PM
moose94
May 10, 2005 11:06 AM
