2005 Ford Excursion
Old May 23, 2023 | 09:26 AM
Dusty Nugget's Avatar
Dusty Nugget
2nd Gear
2005 Excursion
Hey all, I have looked on Google and see soany different fuse panel diagrams. My ac unit display is not working and has no power. Does anyone know where this fuse may be located or have had this problem in the past?
Old May 23, 2023 | 09:27 AM
Dusty Nugget
2nd Gear
2005 Ford Excursion
My ac unit display and is not getting power.. I have looked online and I can't find where this fuse may be located. I'm getting mixed answers. Has anyone else ran into this.
Old May 23, 2023 | 02:45 PM
85e150's Avatar
85e150
Threads merged.
Have you traced the wiring from the AC unit back to the fuse block? Looked at all fuses?
Old May 23, 2023 | 06:47 PM
Maxium4x4's Avatar
Maxium4x4
In the Tech Folder we have an Index of Ford Manuals
Try the Fuse and Relay PDF
Old May 24, 2023 | 07:52 AM
Antonm23's Avatar
Antonm23
Here's what the wiring diagram manual shows for power supply. There are five pages just on the EATC in total, but it looks like there's a "hot in run" and a "hot at all times" power supply to it from two separate 10amp fuses.
Old May 24, 2023 | 11:39 AM
Jokester00's Avatar
Jokester00
I've used this link a few times on my 2005 F350 and so far it's been accurate, but can't speak to the accuracy of the Ex.
Choose a model of Ford - StartMyCar
*EDITED* Weird...no years to choose from after choosing Excursion. Can see everything else though...hmmmmm!
-jokester
Old May 26, 2023 | 06:40 AM
DSMMH's Avatar
DSMMH
Found this on the forum. Your problem is fairly common.
I've had this happen only once (in the 14 months I've owed it).
While driving I turned on the headlights (as others had suggested)
and that fixed mine - never happened again.
I have the 6.0 w/EATC climate control system.
I have a ‘04 X. Had it since ‘05. Had your problem and did the above back in ‘05. Never had the issue again.
Ed
chipper
1997 - 2003 F150
Sep 14, 2016 07:10 PM
Sburton
Jul 22, 2011 07:29 PM
gator120
Sep 15, 2009 06:12 PM
