Hey all, I have looked on Google and see soany different fuse panel diagrams. My ac unit display is not working and has no power. Does anyone know where this fuse may be located or have had this problem in the past?
My ac unit display and is not getting power.. I have looked online and I can't find where this fuse may be located. I'm getting mixed answers. Has anyone else ran into this.
Here's what the wiring diagram manual shows for power supply. There are five pages just on the EATC in total, but it looks like there's a "hot in run" and a "hot at all times" power supply to it from two separate 10amp fuses.
Found this on the forum. Your problem is fairly common.
I've had this happen only once (in the 14 months I've owed it). While driving I turned on the headlights (as others had suggested) and that fixed mine - never happened again. I have the 6.0 w/EATC climate control system.
I have a ‘04 X. Had it since ‘05. Had your problem and did the above back in ‘05. Never had the issue again.
