PATS issues
Old May 22, 2023 | 08:44 PM
chrisjrosenbohm's Avatar
chrisjrosenbohm
PATS issues
Hello all, I’m working on a 2008 f150 5.4 auto trans. 200k. I have a no crank no start. Security red light flashes slowly as normal. When key in inserted and turned on I get a fast blinking. I took it too local lock smith and they where unable to get it to work. They said it has 2 keys programmed and they made a new key still no start. They were unable to reset the immobilizer.
the 2 codes are B1342 and B1601. Any ideas what to do next? Possible bad pcm? If so does pcm need to be replaced along with transceiver and or cluster? Any help appreciated
Old May 23, 2023 | 07:04 AM
projectSHO89's Avatar
projectSHO89
Note that the DTC B1342 can be generated by multiple modules. You have to verify WHICH module is reporting it.
If the B1342 was pulled from the PCM, it indicates that the PCM has self-diagnosed itself as having a fatal internal fault. Try clearing codes and re-running the KOEO self-test and see if the fault clears or not. If not, you might want to contact forum sponsor Circuit Board Medics and see if they can repair a PCM with a B1342. Let us know how it turns out.
The B1601 *might* be due to experimenting or attempting to start with an unprogrammed key,
The cluster has no bearing on PATS functionality (except for the light) on an 08.
Old May 24, 2023 | 01:38 PM
getterdun1's Avatar
getterdun1
I would try to jump start it from the starter motor next.
Old May 24, 2023 | 06:42 PM
projectSHO89
That wouldn't matter. If PATS has not proved out successfully, all that jumping at the starter motor would do is make it crank (best case). It would never fire and run since PATS did not authorize operation.
Old May 26, 2023 | 02:17 PM
getterdun1's Avatar
getterdun1
Good point. Something else learned. Thanks.
JimmyD150155
2009 - 2014 F150
19
Jul 13, 2025 04:39 PM
F150_02
1997 - 2003 F150
Apr 7, 2022 05:37 PM
Mattheweston
Jun 11, 2018 08:29 AM
kountzecobra
1997 - 2003 F150
15
Nov 1, 2016 06:24 AM
Crd16
1997 - 2003 F150
Aug 9, 2016 03:54 PM
