Sponsored by: Real Truck
Electrical system needs for winch ??
Old May 21, 2023 | 03:34 PM
Truck Fun's Avatar
Truck Fun
Question Electrical system needs for winch ??
I'm considering adding a winch a some point to my 2014. Is the OEM electrical system adequate for operating a winch? Thanks.
Old May 21, 2023 | 03:44 PM
WWR's Avatar
WWR
There's a zillion variables but I'm going to say in general, yes.
Old May 21, 2023 | 08:15 PM
apache84's Avatar
apache84
Just dont run the winch under heavy load until you've sucked the battery dead and the alt cant keep up.
Here is a basic rule on winching. How many amps do winches draw?
The amperage your winch draws depends on the amount of load placed on it and how long it's in use. With no load (just spooling in and out) a typical 9,000-pound winch will draw 60-70 amps. It will draw about 250 amps under a 4,000-pound pull, and nearly 480 amps at 9,000 pounds.Jun 21, 2018
Old May 21, 2023 | 10:45 PM
PJWhelan's Avatar
PJWhelan
Would you need a 2nd battery for a winch?
Old May 21, 2023 | 11:03 PM
WWR's Avatar
WWR
Again, a zillion variables including amp draw of particular model, duration of pull, how badly you're stuck, alternator max output, ****** block or no, etc.
In general, yes, it's a good idea but in many cases not required.
Old May 22, 2023 | 08:09 AM
apache84's Avatar
apache84
Like WWR said a ****** block is a very useful item and will double your pulling power basically and/or lower the drain on the system. Use a GOOD recovery line to a tree or another vehicle with the other end landed on the ****** and the end of the winch line returned to a frame hook or acceptable spot. Also keep in mind the bigger the spool of cable the less pulling power a winch has. Pull cable out to the drum with a few wraps and you have a small diameter spool to start which gives greater "reduction" than a full loaded spool.
Old May 22, 2023 | 08:25 AM
jetty's Avatar
jetty
Agreed. For non-commercial applications, where time is not a priority, a ****** block works wonders.
Old May 22, 2023 | 08:51 AM
WWR's Avatar
WWR
As apache mentioned, if using a ****** block, run the hook back to a recovery point on the frame.
Many winch bumpers have recovery points but then you double the pulling load on the bumper itself. It's best to pull the frame to the bumper, so to speak.
Old May 24, 2023 | 08:19 PM
Truck Fun's Avatar
Truck Fun
What is the amperage for the alternator for a 2014 6.2L ?
Old May 24, 2023 | 11:13 PM
WWR's Avatar
WWR
150 or optional 200A
Old May 24, 2023 | 11:25 PM
WWR's Avatar
WWR
At the risk of telling you what you already know, you can send the system into significant deficit for awhile. And truly no system could withstand a full-size truck winch at full load indefinitely unless you can source a 400 or 500A alternator (Cole Hersee maybe?)
Your alternator makes up for a portion of it then you're dipping into your battery reserve but typically you'll be ok. Obviously, turn off any unnecessary electrical loads like HVAC, heated seats, stereo etc
I cut my teeth on OBS Fords with 60A alts on the Windsors. Plenty of guys winched with those. We'd upgrade to 100A Taurus alts or 130A 3G's and that was HUGE back then.
Old May 26, 2023 | 02:46 PM
PJWhelan's Avatar
PJWhelan
Okay, I've got a question since we're talking about alternators. I have a 2002 F-250 CCLB 4WD 5.4L, and I'm not sure what size the current alternator is. Where are the markings for it? Is it stamped on the bottom, back or other location.. Thanks!!!
Mannysouza
Jun 1, 2023 06:36 AM
BrianTheLion
Aug 18, 2021 12:39 AM
KeysMako192
Jun 9, 2020 09:32 AM
Chumbucket
Apr 28, 2006 01:14 AM
stebab
Mar 13, 2006 04:41 AM
