Ravelco
Old Aug 12, 2021 | 01:39 AM
BrianTheLion's Avatar
BrianTheLion
Ravelco
Anyone put a Ravelco system on their truck?
Old Aug 12, 2021 | 12:15 PM
HIO Silver's Avatar
HIO Silver
Talking
An anti-theft system?
Nope. My rig has a manual transmission!
Old Aug 12, 2021 | 12:24 PM
smoky_diesel's Avatar
smoky_diesel
Interesting concept. If it has a coil can still just jumper to 12v and start motor. Hood lock would be needed with it to be robust.
I use an isolation relay to prevent any jumpering under hood or under dash. With EFI, MSD and so on it is not simple to hot wire.
Old Aug 12, 2021 | 12:33 PM
BrianTheLion
HIO so does mine but that apparently doesn't give me as much reassurance as it does you!
Old Aug 12, 2021 | 12:35 PM
BrianTheLion
Thanks for the input Smoky.
Old Aug 12, 2021 | 01:03 PM
Lrrr-RulerOfOmicronP's Avatar
I like the concept but wonder if I would remove it and keep it on my person at all times... I probably would not. Maybe if it was smaller.
I have considered hidden a hidden switch but again wonder how much I would use it.
I have looked at a key pad style switches but do I want to enter a code every time to start it? Key pads can also show the code numbers used if they wear or get grungy.
I like the idea of a RFID key chain like newer cars use for keyless starting but how robust are aftermarket electrics? Will it leave me stranded somewhere?
GPS tracking is the only think I do use. It may be too late by the time it is found though.
So have good insurance is the best option I can think of.
Old Aug 14, 2021 | 05:41 PM
JEFFFAFA's Avatar
JEFFFAFA
If you go somewhere you are worried about, remove the coil wire. Then put it in your wife's purse.
Old Aug 15, 2021 | 12:40 PM
BrianTheLion
Ruler yea I agree maybe not all the time, but I would pull it every night.
Jeffafa, my issue is where I live, I don't have a garage for it and I live on a high traffic road and with the prices going up I'm worried about someone trying to grab it at night...
Old Aug 15, 2021 | 07:39 PM
fe390pc's Avatar
fe390pc
A battery disconnect and a good hood lock. I believe this is your best option.
Old Aug 18, 2021 | 12:39 AM
BrianTheLion
Now that you mention it i am gonna look for a hood latch. With the battery disconnect, do you mean like havin a switch in cab fe390?
KeysMako192
Jun 9, 2020 09:32 AM
donnyonee
2015 - 2020 F150
Feb 11, 2016 02:36 PM
RobbD
Nov 22, 2013 06:55 PM
