Sponsored by: Real Truck
Issues After Head Job
Old May 21, 2023 | 02:46 PM
StoneMech91's Avatar
StoneMech91
2nd Gear
2006 350 lariat with 6.0, before the job truck ran fine but was leaking all over from the lower pan to the heads, valve cover and oil cooler. When I took everything off the valves and pretty much everything on the intake side had enormous amounts of build up.(truck has a delete) replaced the following gaskets, heads, exhaust, intake, oil cooler, oil pump, o rings on dumby plug and pick up tubes, valve cover, valve seals and fuel injector o rings.
I had a minor issue in set back and a valve bridge popped off trying to get it to run. Put it back on and the truck runs sounds “ok” maybe forint air out still. Put it in gear and it seems to bog down slightly and the pitch or the engine goes kinda shaky.
When in gear not pushing the pedal the truck will move push the pedal and it wants to die and blows black smoke. Oil pressure is good but I seem to have no boost pressure, or at least not at the gauges. Could I possibly have a stuck valve? Do I need to scan this or open it back up?
Old May 21, 2023 | 02:49 PM
StoneMech91
2nd Gear
I also lapped the valves they were all good on passenger side but almost out on the intake for drives side.
Thunderkiss1965
46
Jul 21, 2021 05:07 PM
desperado_18_2000
Sep 7, 2011 06:30 PM
frankenstein f-150
Jul 29, 2009 04:37 AM
Six Niner
Aug 27, 2005 12:28 AM
mhyff250
Feb 3, 2001 08:51 PM
