MPG
Old May 19, 2023 | 07:12 PM
  #31
Anonymous12's Avatar
Anonymous12
Originally Posted by DFWF150
OP - yes. Buy that reader. It's a must have item in your garage for these trucks. Also get a Haynes manual or Chiltons. Or both. Then spend some time with the book or youtube learning how to read the KOEO and KOER codes, stored codes, clearing codes, etc. That will help you cut through the fog and know what to chase down first. Don't start chasing several things at once.
I’ll buy that reader, but I do have a Haynes book, and a ford shop manual from LMC
Old May 19, 2023 | 07:21 PM
  #32
Prototypemech's Avatar
Prototypemech
Originally Posted by Anonymous12
Here’s the video of the codes, I must’ve looked away for the second code, would the second be a 13? Or is the 4th flash a part of that code? I think it’s saying it’s done flashing because it doesn’t flash after that. It’s not a 12.
Active codes 11 (No codes stored)
Repeated
Code Separator 10 Between active and memory codes
Memory code 11 (No codes stored)
Repeated
This is how fast the codes blink.
Old May 20, 2023 | 05:34 AM
  #33
yeet's Avatar
yeet
Is this the right one?
Thats the one I have been using. My diagnostic plug on my truck is under the hood on the drivers side fender well so I bought the extension cable as well. It's easier to run the tests from the drivers seat. I'm an old fat guy and running back and forth from under hood to cab was scaring the neighbors.
Old May 20, 2023 | 07:48 AM
  #34
My4Fordtrucks's Avatar
My4Fordtrucks
What were you running for? You don’t need to do anything other than push the TEST button to start KOEO test. If you have a 4.9L there is time to push the clutch pedal. When prompted in the KOER test walk around the door then momentarily smash the gas pedal and if applicable, turn the steering wheel and push the OD cancel switch.
I think your mileage is low but, as others have said, how you drive and short trips will affect your mileage. I got 14-15 mpg in combined city/hwy driving in my ‘89 F-150 (302, M5OD, 3.55 gears).
Old May 20, 2023 | 07:01 PM
  #35
Anonymous12
So, code 11, which means no codes. Then the scanner went 10 to separate to continuous memory, then it went to 11 again saying no codes. But then the C disappeared, and then it said 70. So no codes and no continuous memory codes, why the 70? And why are the readers codes different from the trucks? Did I accidentally reset the codes? I did hold the test button since the thing was taking a while.
Old May 21, 2023 | 07:19 AM
  #36
yeet's Avatar
yeet
70 according to the book that came with my reader is a car only code indicating ECM failure. Are you sure you did the test correctly? Should be no need to hold down the test button. just hit test once and let it do it's thing. The KOER test takes about 5 minutes on mine. It will display all codes detected twice. When it's done I turn the reader off and listen for it to disconnect before unplugging it from the port. Also, keep in mind you should address the KOEO codes first and get those sorted out before moving on to the KOER test.
Old May 21, 2023 | 11:19 AM
  #37
Anonymous12
I’ll redo the test today.
In my book it said ecm failure as well but it said cars only so that’s why I was confused with it.
Old May 21, 2023 | 01:56 PM
  #38
yeet's Avatar
yeet
Try this.
Remove the negative battery cable for 5 or ten minutes. Then drive the truck for a few miles to make sure it is at operating temperature. That is important.
shut the truck off and hook up your tester but do not turn it on
move the key to the on position
now turn the tester on and hit the test button once
you should hear some things clicking
After about 30 seconds to one minute it will start displaying codes
it will go through the displayed codes twice
when it has displayed all codes twice you should see either a 10, 11 or 111 that indicates that part of the test is over.
It will then display the stored codes, but you wiped those when you disconnected the battery at the beginning so it may show the 10, 11 or 111 again.
turn the tester off and shut the key off. You're done with KOEO
Old May 22, 2023 | 01:00 PM
  #39
Anonymous12
I pulled the codes again. Code 70 did not pop up again. Just code 11 so I have no codes. Ill do KOER next when I drive the truck again.
Old May 22, 2023 | 02:24 PM
  #40
yeet's Avatar
yeet
No codes is good!!
RGrew176
2015 - 2020 F150
21
Feb 15, 2021 03:26 PM
snakedoc
Mar 2, 2010 10:37 AM
Bowie
Feb 3, 2008 05:25 AM
dynamis5
2004 - 2008 F150
Apr 22, 2007 05:08 PM
Canadianice
Bronco II
Jun 7, 2005 02:34 PM
