Temp Gauge!
Old Nov 23, 2015 | 01:07 PM
timlange's Avatar
timlange
Temp Gauge!
I am new to the site, and was wondering if someone could help me in trouble shooting my temp gauge. I have a 1997 f350. I brought the truck a year ago and i have still not fix this problem. I install a new temp gauge and nothing changed. When ever the truck is running it reads cold and doesnt budge. Ive read that the gauge can be broken its self but during a few hot times over the summer. The gauge began to rise slower, never reaching normal tempature. A few times i messed with the heat and the gauge would shoot over the normal temp. The truck seems to run at a good temp sometimes hot though. The tube on top of the radiator is hotter than the bottom also. Thank you for you time
Old Nov 24, 2015 | 07:03 AM
JWA's Avatar
JWA
Your problem is probably internal to the instrument cluster.
Old Nov 25, 2015 | 01:13 PM
timlange's Avatar
timlange
By that you mean the gauge?
Old Nov 26, 2015 | 06:52 AM
JWA's Avatar
JWA
Yes or more accurately the motor driving the gauge needle.
FWIW I had a '97 E250 with this same issue, the gauge eventually failing and no longer registering anything at all. A new cluster courtesy eBay fixed the issue.
I've been and am now in the process of dissecting and re-setting the mileage in a cluster with the pre-digital counter. Replacing just that gauge movement is possible I suppose but it does require a bit of knowledge and skill soldering electronic components.
dustyroad
Sep 29, 2018 07:38 PM
49fordv8f4
Jan 25, 2016 10:05 PM
Tcook911
Jul 23, 2014 10:01 PM
machinist91
Oct 1, 2013 09:56 PM
geraldo14
Sep 2, 2005 12:30 PM
