In cab reverse power/lead
Old May 16, 2023 | 11:21 AM
rufushusky's Avatar
rufushusky
I am looking to wire up my reverse/hitch lights and need a reverse light trigger source for switch and relay, I know I could tap into the OEM reverse lights or the trailer wiring harness however I was looking to consolidate the switch and relay in the cab if possible and only have one power line heading down the frame rail to the reverse lights. Anyone know of any reverse source in the cab I could t-tap into?
Thanks in advance.
Old May 17, 2023 | 06:57 AM
Log Hog Kust'em's Avatar
Log Hog Kust'em
I have used the upfitter switches. If no upfitter, tap into an unused fuse and wire a dedicated switch. LED's don't use much power, you won't need a relay
Old May 17, 2023 | 05:04 PM
TB250's Avatar
TB250
Well, in my 2021, C2280C is located in the passenger footwell. C2280c Pin 11 Green with a brown tracer.
Old May 17, 2023 | 06:33 PM
rufushusky's Avatar
rufushusky
Excellent, I will give my 2019 a look. Much appreciated, thank you.
Garbageman 134
Mar 17, 2023 07:45 PM
Trath67
Mar 19, 2021 08:20 PM
AMEC Electric LLC
6.7L Power Stroke Diesel
May 16, 2011 09:28 PM
buckshot047
Apr 21, 2007 05:32 PM
weldman
May 26, 2002 11:05 AM
