ac charging
Old May 15, 2023 | 06:45 PM
oldbird1965's Avatar
oldbird1965
ac charging
Can someone refresh my memory of how to jump start the ac compressor? I had to replace a hose then I vacuumed the system. So, starting out I remember having to use a paper clip to jump the compressor into action to get the system to draw in Freon. How do you do that?? Thanks
Old May 15, 2023 | 08:04 PM
Hit Man X's Avatar
Hit Man X
Low switch on dryer or shoot some gas in to light it off.
It needs 38oz I believe b
Old May 15, 2023 | 08:42 PM
Pickledboater's Avatar
Pickledboater
Yup. What hit man said. I read 2 pounds 6 ounces if completely empty. Basically 2 cans of 134 and a can of oil. Or, 2 1/2 cans. I start the gas going then jump the switch wire. Once you get a can or so in the switch will work like it should.
Old May 15, 2023 | 09:51 PM
oldbird1965
Sounds good but I didn't think I had to put any oil in because I didn't change the compressor. Isn't the oil still in the compressor? Thanks guy!
Old May 16, 2023 | 12:51 AM
fordman67's Avatar
fordman67
When you hook the can up it should provide enough pressure to activate the low side switch. It may cycle a few times while filling but no big worry.
yea oil will be in the various components,just jack it up and enjoy the cold.
Old May 16, 2023 | 04:47 PM
tjc transport's Avatar
tjc transport
i ain't rite
agreed. pull vacuum, and charge. no need to jump anything. the first can will put enough in to get the low side cycling, then the second can will suck in as the compressor turns on.
by the time you get to the third can the compressor should stay running.
134 cans are only 12 ounces, so you need 3 cans for the 38 ounce system.
Old May 16, 2023 | 07:17 PM
oldbird1965
Thanks Tom and everybody else. I'm pretty cool for an old guy now, lol.
On a side note while I had the gauges etc out I checked out my old 1998 VW Beetle. Cooling lately has been intermittent so I found out that the high side is over 400! Low side is normal but google said its either overcharged, blockage somewhere or the compressor is about shot. I can believe that the compressor might be on its way out, its had a very hard life. First I'll try to get the pressure down, I don't think there is a blockage but I'm guessing a new compressor is in the future.
Old May 17, 2023 | 04:16 AM
tjc transport
i ain't rite
with a high side of 400, i would be leery of standing close when running.
the rubber hoses tend to blow around 500 psi. (yes, i know this from experience)
i would bet there is crud in the system from a failing compressor blocking the orifice tube.
Old May 17, 2023 | 10:24 AM
Hit Man X's Avatar
Hit Man X
Check the condenser for any blockage and fan(s) for operation.
Fixed an old Honda with dual fans that had crap temps at idle due to one fan being dead.
Old May 17, 2023 | 10:30 AM
joshh's Avatar
joshh
before throwing parts at the VW look at cooling fans and condenser for trash on it can spray water on it to see if pressure drops a lot
in my experience when high goes way up low side drops a lot from a blockage, but low side stays up with poor cooling of condenser
tsmithco
Feb 13, 2023 05:49 AM
bluefeather300
Jun 2, 2022 02:27 PM
Ljblue
Feb 8, 2022 02:22 PM
Grantford
Aug 25, 2019 01:08 PM
zuikoman
Sep 26, 2008 08:09 AM
