Sponsored by: Real Truck
Lil AC help needed
Old Aug 23, 2019 | 11:52 AM
Grantford's Avatar
Grantford
Lil AC help needed
Got this truck couple months ago
2008 f250 5.4gas
ac blew cold only on driver side and from what I understood I needed to replace the passenger blend door, but
yesterday ac compressor stopped!!! No cold air, I only have the low side gauge but it was on 150psi in the red.
not sure what to other than get both gauges and get some better numbers, the compressor does not come on
Old Aug 23, 2019 | 03:43 PM
projectSHO89's Avatar
projectSHO89
That would be a normal reading when the underhood temps are high and the compressor isn't running. You have to figure out the WHY of the compressor not operating.
Is the truck equipped with dual climate controls?
Old Aug 23, 2019 | 10:56 PM
Grantford's Avatar
Grantford
It does have dual controls
I’m not sure if it being messed up would have effects on the compressor.
Old Aug 24, 2019 | 04:42 AM
416bigbore's Avatar
416bigbore
Hello, I would first check the AC fuse, then check to see if your AC compressor is good and will kick on by jumping power across your AC relay. Your AC system has a low pressure switch in the system that will shut the compressor off to protect it until you have enough Freon in the system to run it. Unless your compressor is bad ? My guess is that your Ac system has a slow leak in it and the low level of Freon in the system is keeping the compressor from kicking on. If this is the case and your compressor is good, you will also have to have the AC compressor running when charging the system or it will not draw the Freon into the system. I am in no why an AC expert, I just know enough to keep my own AC operational. Good Luck
Old Aug 24, 2019 | 08:06 AM
projectSHO89
If the refrigerant had leaked out, he wouldn't measure 150 psi static pressure. Next.
No effect. It's independent.
Without your knowing how the PCM-controlled A/C system is supposed to work, here's a couple of simple things you can do to.
IMPORTANT: Certain engine-related faults will disable the A/C system to limit the load on the engine. Scan the PCM for faults FIRST.
Check the clutch gap (if it's excessive, it won't engage).
Check clutch connector.
Check fuses F30 & F70 under the hood.
Swap the A/C clutch relay for an identical relay that is not critical for operation of the engine.
Locate and jumper the low-pressure cycling switch to see it's failed open
Locate and jumper the two CORRECT pins of the high pressure dual function switch to see it's failed open. (Blue-green & gray wires).
Check the wire harnesses at both of those switches for damage or open circuits.
After that, you have to get serious.
Old Aug 24, 2019 | 06:09 PM
Grantford's Avatar
Grantford
It was the ac clutch diode
Old Aug 24, 2019 | 06:25 PM
projectSHO89
That would be highly unlikely. The diode isn't even needed for the clutch to operate. It's only there to keep other stuff from getting fried when the clutch is de-energized.
Old Aug 25, 2019 | 10:17 AM
Grantford's Avatar
Grantford
Well the ac clutch fuse #30 10amp was jumped, I put in a new one 3 times just to watch it pop. I checked the clutch diode and it was jumped, put in a new one and a new fuse and it works!!!
Old Aug 25, 2019 | 01:08 PM
projectSHO89
Well, if the diode was "jumped", that's why the fuse blew! Dead short to ground.
Now, how the hell did it get "jumped"? The compressor would never have run with that in place.
hardeyf150
2009 - 2014 F150
Mar 13, 2017 06:39 PM
jake22si
1997 - 2003 F150
Jun 28, 2015 09:04 AM
mrgn_mtt
May 13, 2008 10:59 AM
302VAN
Apr 3, 2008 03:22 PM
Psycho Sasquatch
Aug 31, 2007 11:55 AM
