Sponsored by: Real Truck
Another DEF fault...
Old May 15, 2023 | 09:44 AM
LocutusOfBork's Avatar
LocutusOfBork
Trailering
2012 F250... third DEF fault since February. The other two were 207 (DEF fluid quality) and were cleared when the DEF module and NOx sensor were replaced (first time with used parts, second time with new parts), but the fault came back both times. After the new parts were installed, it took about 200 miles or so before the fault appeared again. I'm reluctant to check the fault code because the truck is threatening to drop into idle mode, and I still want to be able to drive it to the local diesel shop. Can you check a code without starting the engine?
Old May 16, 2023 | 06:42 PM
masonlift's Avatar
masonlift
Yes. Just need key in on position to retrieve codes
jwsrules
6.7L Power Stroke Diesel
May 28, 2025 11:46 PM
Abelj
Apr 8, 2019 06:19 PM
Luke Guihan
1978 - 1996 Big Bronco
Jun 30, 2016 08:03 AM
snorton85218
Mar 1, 2010 09:06 AM
SLMDLM
Jan 20, 2009 10:12 PM
