Stereo Losing Settings
Old May 11, 2023 | 06:52 PM
triton54's Avatar
triton54
So, my 2019 XLT SCREW recently updated and worked fine for about 2 months. About two weeks ago, it decided it would stop keeping certain settings (night mode, touchscreen beep off, last channel listened to).
I get in now after it sits all night and the touchscreen beep is on, its on "auto" mode versus night, and always on FM radio when I exclusively listen to carplay or SiriusXM. I had the battery checked because it was the original and some things like auto start/stop weren't working. Battery showed "going bad" so replaced it and the start/stop works fine. I've done two master resets and the power/fwd buttons to reset as well, no luck! Could the APIM be going out? I'd like to think I'd have worse issues if so, or is the update just bugged perhaps? What am I missing here?
Old May 11, 2023 | 09:00 PM
85e150's Avatar
85e150
Did you have the BMS reset for the new battery? I think I had that done as I asked the dealer to do it, but I'm not sure.
AGM battery again?
Old May 12, 2023 | 11:58 PM
CKNSLS's Avatar
CKNSLS
Yes-it could be the APIM.
Old May 13, 2023 | 11:30 AM
triton54's Avatar
triton54
Tried BMS reset and the battery was almost $300 so it better be AGM. It is what came up for the truck when the make/model etc was entered (die hard brand). If it is the APIM, a quick search shows it to be a $900 part. I can't see something lasting 4-5 years that is this vital to the truck costing this much. If it goes out I'll def go aftermarket so I wont have to worry about it in another 4 years.
Old May 13, 2023 | 03:28 PM
CKNSLS's Avatar
CKNSLS
You can get them for less-
https://naviupgrade.com/shop/hardwar...s/sync-3-apim/
Also Amazon is showing some for around $292.00
Also ask the Ford dealer if Ford Corporate can "cooperate" on a replacement for less than retail. It's a well known failure issue. I don't think there are many companies that make these things.
Old May 17, 2023 | 12:57 PM
bogeyrider63's Avatar
bogeyrider63
Trailering
Anybody find a fix for this yet? It is getting annoying.
Old May 17, 2023 | 12:59 PM
CKNSLS's Avatar
CKNSLS
FIX?
The fix is in all likelihood a new APIM. $300 to $500 depending where you get it from. Plus a couple of those plastic tools to pry the top of the dash apart.
Old May 17, 2023 | 01:30 PM
JKBrad's Avatar
JKBrad
APIMs on Sync3 are a huge pain in the ***, high failure rate. You might want to go to Crutchfield or you local car stereo shop and see what aftermarket options there are.
Old May 17, 2023 | 02:54 PM
CKNSLS's Avatar
CKNSLS
The Sync 3 doesn't leave you with much options. And what those options are costs more than a new APIM.
frysl
Dec 16, 2021 12:13 PM
JWUC
2015 - 2020 F150
35
Nov 24, 2019 12:06 AM
dcsmith
2004 - 2008 F150
Aug 5, 2017 07:06 PM
cstoc235
2009 - 2014 F150
Jan 31, 2016 01:23 PM
gofastbig3
1997 - 2003 F150
Nov 9, 2000 12:27 PM
