Truck problems
Old May 11, 2023 | 04:59 PM
FordBronco101214's Avatar
FordBronco101214
2nd Gear
Truck problems
Got a 1995 f150 with 302 injectors are not pumping, replaced fuel tank, pump, and filter was could cause the injectors not spraying, took a few off and they look clean and advise is greatly appreciated thanks
Old May 11, 2023 | 07:25 PM
My4Fordtrucks's Avatar
My4Fordtrucks
Are you saying you replaced the pump because the injectors aren’t spraying fuel? The computer tells the injectors to turn on so replacing the pump wouldn’t have fixed that problem. Was the truck sitting for a while or did this happen on a truck that was being used regularly? Do you have spark? Have you checked for key on engine off (KOEO) fault codes? Have you checked fuel pressure with a mechanical gauge?
Old May 11, 2023 | 09:52 PM
FordBronco101214
2nd Gear
yes truck was sitting for 10 yrs and fuel tank was rusted so we just replaced everything and blew out the lines and yes I have spark and no haven’t checked for codes yet I ordered a code reader but waiting for it to come in. Was going to see if anyone else had a better idea that I could run through till my code reader came in
Old May 11, 2023 | 11:35 PM
My4Fordtrucks
The injectors are more than likely bad from sitting. The easiest thing to do would be to plug in a noid light to verify that the computer is turning the injectors on and off.
Old May 12, 2023 | 08:28 AM
manicmechanic007's Avatar
manicmechanic007
Is the fuel pump working?
Test the pressure and then yes, buy or rent a set of noid lights
Old May 12, 2023 | 11:27 AM
My4Fordtrucks
Are you doubting the quality of the new fuel pump?
Old May 12, 2023 | 02:19 PM
manicmechanic007
Yes, and or the contents of the tank plugging up the sock
Take a fuel sample
Test volume and pressure from the pump
I suspect no problems because you replaced the tank but the test is needed
I tape my fuel pressure gauge to the windshield during days of testing sometimes
That is one way of diagnosing intermittent relay or wiring faults
You can just use a test light on the injectors and forgo the fancy noid light
Check your VREF (the 5 volt reference the computer supplies to a few sensors like the TP sensor)
Good luck
Tommee
Aug 21, 2017 04:39 PM
119er
Jul 19, 2013 09:56 PM
hurlstone
Feb 11, 2013 05:20 PM
briancooper
Dec 29, 2012 10:52 PM
Kingtim7
Apr 26, 2005 12:48 PM
