NP205 Speedo adaptor
Old May 10, 2023 | 05:49 PM
J ballan's Avatar
J ballan
Does anybody know if the Autometer 5292 adaptor will fit in my NP205 transfer case so I can run an Autometer Speedo? Thanks in advance
Old May 11, 2023 | 06:21 AM
ranger140892's Avatar
ranger140892
Grumpy goat
I put one in my 205 when I installed a new wiring harness. That, coupled with an Auto Meter electronic speedometer works great.
One suggestion: Install a new nylon speedo drive gear on your transfer case's output shaft. Even if it's not showing symptoms, it's probably very worn and could cause problems with the new electronic speedo. With your factory speedo, if you have any needle bounce, you need to replace the drive gear. It's an easy task. Scroll down the link below, and you'll see what your drive gear probably looks like.
https://www.ford-trucks.com/forums/1...choices-3.html
Old May 11, 2023 | 06:43 AM
J ballan's Avatar
J ballan
Thank you very much for your help! I’ll get one ordered
Old May 11, 2023 | 06:48 AM
ranger140892
Grumpy goat
You're welcome. Keep us updated.
jason832
Oct 17, 2015 06:01 PM
Diesel_Brad
27
Nov 3, 2013 09:32 AM
greywynd
Nov 24, 2011 12:14 AM
wreckinball
Mar 8, 2011 02:24 PM
ford429cu
Nov 28, 2002 08:29 PM
