Speedometer Solution?
Old Mar 8, 2011 | 12:18 PM
wreckinball's Avatar
wreckinball
Auto Meter
Would that sender plug into the transfer case slot? It says ford plug in. If so i am getting a speedo asap. Let me know what you think.
Old Mar 8, 2011 | 12:37 PM
juni88126's Avatar
juni88126
You might not even need it. It sounds like that is used on the mechanical speedo trucks not on our were it is already electronic. Get ahold of autometer and let them know what you have and they would be able to tell you if you would need it.
Old Mar 8, 2011 | 12:39 PM
juni88126's Avatar
juni88126
What is wrong with yours?
Old Mar 8, 2011 | 12:53 PM
wreckinball
ive never had a speedo, the speedo in it is from something, dont know what from, with the .104x.104 square cable, but the transfer case has the electric sender. I really just need a stock ford speedo but hard to find in canada. Going to replace with an autometer solution if i cant get it figured soon.
Old Mar 8, 2011 | 01:40 PM
Lazy K's Avatar
Lazy K
That should work with yours. Only problem is you might have to change the speedo gear if the transfer case is not original to the truck. But you might get lucky.
Old Mar 8, 2011 | 02:24 PM
juni88126's Avatar
juni88126
Does your truck have the 94 speedo in it or is it the earlier body style? Does it have the abs rear brakes?
88beast
Jan 9, 2014 08:10 PM
deanjet
Mar 9, 2010 07:28 AM
pintoches
Aftermarket Products
May 6, 2009 12:18 PM
Aeroman59
Aerostar
19
Dec 20, 2008 07:47 AM
