Another A/C vent question
Old May 10, 2023 | 11:02 AM
richart's Avatar
richart
Trailering
A/C works perfect when 7.3 is under load. But when coasting the cool air turn hot! And it keeps blowing hot air until the next hill pull and immediately goes back to cold air. Should I start replacing every vacuum line? F350 DRW
Old May 10, 2023 | 11:35 AM
knottyrope's Avatar
knottyrope
open hood and near passenger side is the vac hose to a vent valve in the corner that gets rotted out
right after truck is turned off, change selector to see if each valve works and listen for leaks (hissing)
you can put on a 3/4 ball valve wiht barbs and hose clamps with one cut on heater line to block off the flow for cooler AC too
Old May 10, 2023 | 11:47 AM
richart's Avatar
richart
Trailering
Knottlrobe
thanks! I will have someone help me this afternoon. I am to hard of hearing to be able to hear hissing. Lol
Old May 11, 2023 | 07:10 AM
DanielT28's Avatar
DanielT28
you must be married. Selective hearing. 😆
ford4x477
13
Oct 21, 2021 05:13 PM
amexjoe
2009 - 2014 F150
Jul 6, 2020 04:05 PM
Mr. G
Dec 29, 2006 01:30 PM
cwminard
Sep 8, 2004 07:09 PM
bax
1997 - 2003 F150
Feb 2, 2004 11:23 PM
