No hot air on my truck
Hello everyone,
the weather is changing here on the bay area and I just note that I don't have hot air on my truck,any one here that can steer to the right direction on solve this problem.
it blow air and everything but not hot air.
sorry I forgot to add that my truck have 390 engine and it is 1977 f250
Thank you,
Thank you,
The following users liked this post:
do you have AC? AC equipped trucks have a vacuum controlled water valve inline with one of the heater hoses under the hood. Non-AC trucks control the heat via a cable connected to a door under the dash.
Also could be caused by your thermostat being stuck open and the engine never reaches normal operating temps.
Make sure the control cable that flips between hot and cold is attached. There is a small lever just under the glove box on the heater box. The cable should be held on by a star washer. Sometimes those fall apart and the cable can come off the lever. I only know this because mine did one time.
Des the lever slide really really easy? If so the cable might have broken or come loose from the lever. Would need to try and look up under the dash at the back of the heat,/cold controls or pull them to see. I missed where you said you had air. I dont have that so I may be talking out my butt....lol
Bergj1
06-16-2003 08:43 PM
