How to keep the E4OD COOL?
Old May 9, 2023 | 06:03 PM
DanielT28's Avatar
DanielT28
Towing in town whether I manually shift or just put it in D my trans is getting hot. I already have a aftermarket cooler. Going 35mph or less. I hit 230°F. It’s 50°F out too. 14k lbs
One of my 3 loads
should I get a fan on my cooler or what’s the secret for stop and go traffic? What’s the secret when it’s 95°F out too 😱
Old May 9, 2023 | 06:35 PM
cleatus12r's Avatar
cleatus12r
Butt-Head
The stock 95-97 air to oil transmission cooler is barely larger than a power steering cooler (and barely adequate for that purpose too).
Your biggest hurdles are slow speed, large tires, high transmission gear ratios, and a high stall speed torque converter.
Old May 9, 2023 | 06:37 PM
fordman67's Avatar
fordman67
I have the trucool 40k unit. Its worked great for me.
Old May 9, 2023 | 06:58 PM
97-psd's Avatar
97-psd
6.0 trans cooler is a good option to cool it down
Old May 9, 2023 | 07:27 PM
Briansshop's Avatar
Briansshop
What's the gearing?
Old May 9, 2023 | 07:49 PM
DanielT28's Avatar
DanielT28
My trans cooler looks aftermarket. It measured out to 7” x 11”. If I remember right, my brother has a stock cooler and his was like 6” x 8” I think.
Tires are 35s. And I’m not sure about gearing. I’ll look up the axle code.
Old May 9, 2023 | 07:58 PM
DanielT28's Avatar
DanielT28
I want to try it. Online it says not intended for use below 32°F though. Here in northern Idaho it was -0 to -10 for like a week this year. So that probably won’t work. Dang.
Old May 9, 2023 | 08:26 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Does your ATF go to the radiator cooler and then to the aux cooler?
Is the aftermarket cooler a tube and fin or stack plate? A tube and fin has one tube that snakes back and forth with fins connecting them. A stacked plate has stacked flattened tubes that go from one side to the other.
Old May 9, 2023 | 08:33 PM
DanielT28's Avatar
DanielT28
I’ll take a pic
Old May 10, 2023 | 08:45 AM
oldbird1965's Avatar
oldbird1965
I have the 32 row 6.0 cooler and never have a problem with heat even in stop and go traffic. My problem is 'heat soak' with radiator, ac condensor, trans cooler all up front causing my ac cooling in traffic to get really bad. New compressor, evaporator cleaned and fan cleaned. I have to get rolling for cool air. If this isn't true with most of you guys I would like to know your secret, I also have the cut off valve to stop flow to heater.
Old May 10, 2023 | 08:56 AM
knottyrope's Avatar
knottyrope
Originally Posted by oldbird1965
I would like to know your secret, .
shakes my hand
Old May 12, 2023 | 08:07 PM
z31freakify's Avatar
z31freakify
I have a cooler for a SD V8 or V10 CRS, and it's does great, 15k towing in city traffic and temps just hover over 200°
and like Glenn AC sucks in city traffic.
Old May 12, 2023 | 09:02 PM
DanielT28's Avatar
DanielT28
My truck has a bigger than stock transmission cooler on it already but it’s only 7” x 11, I haven’t had time to take a picture anyway it does fine when I’m moving back as soon as I start to go in to stop and go traffic it gets hot
Old May 12, 2023 | 09:05 PM
Mark Kovalsky
Once again, does it have a cooler in the radiator?
Old May 13, 2023 | 07:30 AM
97-psd's Avatar
97-psd
7x11 is on the size of a piece of paper. The bigger coolers give more surface area for the displaced of heat and keeping the trans cool. Like Mark is noting. The style of cooler is also important. Take a look at the 6.0 for a comparison in size.
