Sponsored by: Real Truck
Speedometer Calibration 2003 SD ?
Old Nov 17, 2003 | 08:28 PM
sno jet's Avatar
sno jet
I changed my tire size thinking I could go to my dealer and get the speedometer re-calibrated and be good to go.
I know it may sound silly but I went lower profile tires, I have my reasons.
My dealer told me the 2003 is gear driven at the transmission and then turns it into an electrical pulse, then sends it to the speedometer.
He also stated the gears make about 4 mph jump for each size change.
Is this truly the case or is he mistaken?
Old Nov 18, 2003 | 04:17 AM
Monsta's Avatar
Monsta
Sit. Stay.
First off, welcome!
Did your dealer recalibrate your speedo for you?
What size rim & tire do you now have?
I may be mistaken for the 03s but on other SD trucks the speedometer gets its input from the speedo sensor on the rear diff. It reads the pulses from the ring gear. (simplified term)
I'm not sure what you meant by this: He also stated the gears make about 4 mph jump for each size change.
Sounds false.
Old Nov 18, 2003 | 04:43 AM
Autobahn F-250 Lariat's Avatar
sno jet'
As monsta said what is the new tire size. What was the old size and what gear ration do you have. A little more info please.
Manny
Old Nov 18, 2003 | 07:28 PM
sno jet's Avatar
sno jet
OK, here goes. I changed my tire size to 245/75-16 E. I have 3:73 gears. I checked under the truck and there is a wired type plug-in on top front of the rear differential. I checked the Hypertech web site and it shows no adjustability for the diesel SD. for tire or axle ratio ability. My math shows a 3.73199% fast speedometer reading, this equals 2.8 mph at 75. This isn't a big deal but I'd like to have it close and have a GPS unit to dial it in.
Jet Performance makes an "accu-speed" for some of the vehicles. has anybody tried this one.
I'd still like to have something more like a factory calibration and keep shift points, ABS, and speedo all insink.
Any help is appreciated.
Old Nov 18, 2003 | 07:43 PM
Yeti's Avatar
Yeti
The TRUESPEED is also a option, people who use them say they are very accurate
Old Nov 21, 2003 | 07:11 PM
V10man's Avatar
V10man
Just figure out the rev per mile of the new tires and have your dealer set the PCM to that number.
Old Nov 22, 2003 | 01:57 AM
Sno jet,
Try this site it'll have your answer for the speedo ? .
http://www.mgbexperience.com/misc/tirecalc.html
Old Nov 23, 2003 | 10:56 PM
Motoxman_117's Avatar
Motoxman_117
I installed a truesped and love it. you can set it to run 2 sets of tire combos at the flip of a switch. not to hard to install either.
MotoX
Old Nov 25, 2003 | 11:07 PM
sno jet's Avatar
sno jet
Just ordered a true speed, that way I have the option to change it when I need to. Checked my speedo with GPS, I was 5 mph off at 75mph
Old Nov 27, 2003 | 02:42 AM
Motoxman_117
I think you will be happy with it. I got mine within 1 mph with a 12 channel gps on a clear day with cruise control set. Stock the ford speedo was around 2-3 off comparing to my gps when the truck was brand new, so the truespeed should hook you right up bro.
MotoX
IowaJack
2009 - 2014 F150
Jan 4, 2015 08:14 PM
mriplaybass
1983 - 2012 Ranger & B-Series
Oct 26, 2010 04:49 PM
RIKIL
Feb 17, 2010 09:45 PM
blinkjs
Mar 25, 2009 09:14 PM
Hobie16
Jan 22, 2008 02:18 PM
