Speedometer error
Old Jul 26, 2010 | 02:20 PM
mriplaybass's Avatar
mriplaybass
Speedometer error
Is there a way to calibrate the speedometer on a 91 Ranger? This is my son's truck, and he has about a 12 mph error. When going around 65 mph, the speedometer reads around 77 mph. I have read numerous posts on this topic, but none of them seem to fit our problem. When we drive 65 according to the speedo, the GPS shows around 54 and the traffic backing up behind us supports the fact that speedo is way off! I had to replace the transmission recently, and the problem is the same. Tire size has not changed since the truck was new. Any ideas?
Old Jul 26, 2010 | 04:03 PM
martin_csr's Avatar
martin_csr
... Just a guess.... defective speed sensor?
Old Jul 26, 2010 | 04:33 PM
mriplaybass
Thanks Martin, I'll give that a try. Do you know where the speed sensor is located?
Old Jul 26, 2010 | 07:36 PM
Eaglefixer's Avatar
Eaglefixer
Mounted on transmission
Old Jul 26, 2010 | 09:36 PM
michigan66's Avatar
michigan66
When you replaced the transmission, did you use the speedometer driving gear that came with the replacement tranny. If so, it may have been set for a different axle ratio than you have. If that is the case and you have the old tranny, use the gear from it in place of the one you now have. Otherwise you can get the proper gear from a Ford dealer. All they need to know is the ratio of you rear axle.
Old Jul 26, 2010 | 09:37 PM
reddog99's Avatar
reddog99
There's a gear on the end of the speedo cable. You need to get one with fewer teeth (I think).
Old Jul 26, 2010 | 09:42 PM
mriplaybass
Thanks all for the replies. Maybe I did not make myself clear. With the old transmission the speedo just decided to go nuts out of the clear blue one day. Then when I replaced the transmission, I thought this would solve the speedo problem, but the error was identical. I tend to lean away from the transmission being the cause. Could the problem be in the speedo itself?
Old Jul 27, 2010 | 12:35 AM
Rangerman Stan's Avatar
Rangerman Stan
Yes it could be the speedometer since nothing else has been changed. Two options. Find a speedometer repair shop to fix it or replace it with one from a wrecking yard. Only thing about that is the indicated mileage will not be what you have. Speedometers that will work: Ranger, 89-94. Explorer,90-94. Bronco II, 89-90. Had one on my 90 Ranger that would increase the speed on me in the winter. Summer time it was ok. Had over 239,000.
Old Jul 27, 2010 | 08:43 PM
reddog99's Avatar
reddog99
Before you go thru the trouble of replacing the speedo, be sure to check the cable. A bad cable can cause erratic behavior.
Old Jul 28, 2010 | 08:56 AM
martin_csr's Avatar
martin_csr
This might be stupid, but when they replaced the transmission, did they also replace the speed sensor?
I don't know anything about your ranger, or even speed sensors for that matter. doh.
Old Oct 25, 2010 | 08:36 PM
swensonm's Avatar
swensonm
Speedo off
Howdy
Today I was working on the speedo. I replaced the worm gear on the odometer and not teh speedo is running fast. Does any one know if the speedometer can be recalibrated? No gear have been changed on the tranny. Just the worm gear on the speedo....thoughts????
1996 2.3 5 speed Ranger
MIke
Old Oct 26, 2010 | 12:19 PM
Bidwell's Avatar
Bidwell
Call around and ask if it can be repaired/recalibrate. Calls cost nothing.
Old Oct 26, 2010 | 04:49 PM
lrd56's Avatar
lrd56
i have a 96 ranger splash it has a electronic speedo the speedo gear hooks up to a
generator that tells the speedo what speed your going.i adjusted mine by checking
it by using mile markers.and different speedo gears.my speed sensor is in the rear axle.the wrong tires will make the speedo read wrong
good luck
lrd56
sleddog60
Sep 23, 2014 11:02 PM
Vin Man
Apr 24, 2012 05:29 PM
cjspack
6.7L Power Stroke Diesel
16
Feb 17, 2012 03:35 PM
Gary Lewis
Feb 3, 2012 08:42 PM
Hamguy
Nov 20, 2010 06:40 AM
