1985 4.9 i6
Old May 7, 2023 | 12:37 PM
alanflores2017's Avatar
alanflores2017
1st Gear
1985 4.9 i6
Im new to carburetors, still learning, I'm not getting any fuel to the carburetor even after changing the fuel pump and the sending unit any idea what I might need to do?
Old May 7, 2023 | 03:37 PM
Franklin2's Avatar
Franklin2
Take the hose off the fuel pump going to the rear and put a longer one on it. Stick it down in a lawnmower gas can and see if it will run on that.
Old May 7, 2023 | 08:19 PM
FuzzFace2's Avatar
FuzzFace2
You did use new rubber hode and if so what size?
I can tell you using 3/8 hose from pump to can on fender it will not pull fuel even with 2 clamps.
It uses 5/16 hose at tank & at pump.
Dave ----
Old May 8, 2023 | 06:40 PM
BigBlue2's Avatar
BigBlue2
When I read that you changed the fuel pump and sending unit in the same breath I wonder which fuel pump do you have?
I'm not sure but some later model bullnoses used EFI. The 4.9 may have been built with a carb all the way through 86, but at some year it went EFI. What type of fuel pump did you replace? Even some carb 4.9's may have switched from mechanical to electric fuel pumps because of vapor lock. The two Daves will know which years are which. I expect we'll hear from them. Anyway it will help to diagnose your issue knowing which fuel pump you are talking about.
Old May 9, 2023 | 06:09 AM
FuzzFace2's Avatar
FuzzFace2
All 80 - 86 4.9 motors used a mechanical motor driven pump and carb.
83 - 86 the carb went feedback controled by a computer.
87 the 4.9 went EFI till the end.
Dave ----
Old May 9, 2023 | 08:11 AM
Olds64's Avatar
Olds64
Is there an inline fuel filter that could be clogged?
Old May 9, 2023 | 08:28 AM
FuzzFace2's Avatar
FuzzFace2
I am pretty sure the factory one screws into the carb that the fuel line connects to.
There could be another that a PO installed before or after the pump.
Dave ----
Old May 9, 2023 | 10:43 AM
BigBlue2's Avatar
BigBlue2
Usually a clogged fuel filter slows fuel production which can affect performance prompting a filter replacement. While renewing the filter is a good idea getting no fuel to the carb may point to a bad fuel pump. If the tank is full of rust then a filter could be completely plugged but performance of the engine would have suffered getting there. When replacing the sending unit was the tank removed, inspected and cleaned out?
Old May 9, 2023 | 07:38 PM
Franklin2's Avatar
Franklin2
Most factory fuel filters have a spring behind the filter. When it clogs the pressure from the pump pushes the filter back and lets fuel go around the filter.
4EyedTurd
Feb 23, 2023 07:49 AM
chenson48
Mar 23, 2022 09:44 AM
85Blondie
Aug 28, 2013 01:16 PM
D. DeBoer
Dec 28, 2004 02:54 PM
ODB2
May 20, 2004 04:55 PM
