Vacuum mis-reporting to ecm
Old May 5, 2023 | 07:53 PM
femustang's Avatar
femustang
4wd Low
I have a 91 F150 5.0 E4OD that had a blown head gasket a while back. I have it put back together and running but I get a stumble at idle and fuel economy is bad. I used a Bosch 1300 to pull live data and this is one frame of what I got.
Record Data
FRAME: -4 TM: -0.5
CANST PURGE On
ECT(V) 0.6
ECT(°F) 189
ENGINE SPD 952
EVP(V) 0.4
EVR(%) 0
FUELPW1(mS) 6.0
IAC(%) 53
IAT(V) 1.3
IAT(°F) 144
LOOP STATUS Open
MAP("HG) 10.6
O2SEN 1(V) 0.87
SPARK(°) 15
ST FTRM1(%) 8
TP MODE C/T
TPS(V) 1.0
VPWR(V) 14.0
VREF(V) 5.0
VSS(MPH) 0
I had a vacuum gauge hooked up at the that was sitting at about 20 inhg at the same time I took the data I have 5.0V ref at the sensor and the frequency is pretty close to a chart I found when I use a vacuum pump I have even tried 2 different ECM and 3 different MAP sensors nothing changes. I did note in the Ford shop schematics it shows a potentiometer and I have 5.0 V on the sensor wire going to the ecm with no sensor plugged in. next I'm going to trace the wires from the ecm to the sensor to make sure nothing has failed there. Has anyone seen this before?
Old May 6, 2023 | 10:50 AM
wwhite's Avatar
wwhite
I'm dealing with a hard cold start issue, and a whistle noise during high idle and load, and slight stumble once in a blue moon.
Whistle noise is definitely a vacuum leak.
Finally, yesterday found the culprit. The EGR valve is leaking/sucking air. Going to replace that today.
Bad EGR can give you poor economy.
Old May 6, 2023 | 04:11 PM
TobyB's Avatar
TobyB
No help with the MAP sensor- although I've had similar problems-
but you're also open- loop with a coolant temp of 187f. How's your oxygen sensor?
The ECU would love to use it to lean the engine out, as the base
(open loop) maps are pretty rich.
fwiw,
t
Old May 6, 2023 | 07:12 PM
Conanski's Avatar
Conanski
Yeah you have to figure out why the PCM is still in open loop at that operating temp, idle speed is also high(should be 650-700) and closed TPS should be under 1v... TB set screw may have been tampered with
Old May 7, 2023 | 12:23 PM
rla2005's Avatar
rla2005
Some good info here on the MAP output values displayed by your scanner:
Old May 26, 2023 | 08:38 PM
femustang's Avatar
femustang
4wd Low
I checked the valve itself. It holds vacuum and moves with changes still could be the position sender or the control. I'm gonna do some more testing this weekend.
Old May 26, 2023 | 08:47 PM
femustang's Avatar
femustang
4wd Low
Hi Paul, Thank you for the reply. I need to reset the TB I drove it around the block after figuring out that a transistor in the ecm was blown and causing four of my injectors to fail. This was initially caused by the insulation on three of the injectors getting hard and crumbling from age and shorting the additional current was too much for it. What temp should the loop close? I did pull that data shortly after a restart. I had shut it down to check some vacuum lines and the EGR valve and when I restarted it it started to rain so I just pulled the data and closed up for the evening. I'll get the idle in line tomorrow then check the EGR position sensor and control valve. Maybe the high idle is why the ECM can't identify the cylinders during the KOER test?
Old May 26, 2023 | 08:50 PM
femustang's Avatar
femustang
4wd Low
Thanks for the input! I was thinking the map signal should jive with the gauge.
Old May 26, 2023 | 08:52 PM
femustang's Avatar
femustang
4wd Low
fwiw,
t
I just changed it but haven't pulled the data since. I was concerned it got contaminated when I had to put some head gasket sealer in to limp it home.
kirbykoon
Oct 14, 2010 05:23 PM
Black79
Jun 21, 2010 04:14 PM
jasonmichel
Dec 8, 2007 06:26 PM
southsidej
Aug 29, 2005 11:43 AM
Kwoverby
Jul 16, 2003 09:03 PM
