Vacuum question/ 88 F150 EFI 5.0
Old Jun 30, 2005 | 12:01 PM
southsidej's Avatar
southsidej
Can someone tell me what the hard black vacuum line, "J shaped" on the top of the throttle body and running to a switch, or sensor mounted on the firewall, passenger side, is? I've been checking for vacuum leaks, haven't found any, so far. Just replaced IAC, EGR, plugs, fuel filter,cap, rotor, and wires. The truck won't idle and surges at stop lights,accelerates hard like a plugged converter.Converter replaced also.The reason I ask about that particular vacuum line is, when I unplug it from the sensor on the firewall the truck idles almost normal,but blows black smoke from exhaust pipe. When I connect it again the truck stalls and runs like"you know what".. Ive spent so much money trying to find and fix this problem, I'm almost ready to give up and sell the beast, as is. Any help is appreciated.
Old Jun 30, 2005 | 04:25 PM
EPNCSU2006's Avatar
EPNCSU2006
The sensor on the firewall is the MAP sensor. It is the main sensor used by the computer to determine engine load. That could be your culprit, but I would test the sensor before buying a new one; they are rather expensive.
Old Jun 30, 2005 | 05:28 PM
southsidej's Avatar
southsidej
Thumbs up
is the map sensor computer controled or vacuum activated and can it be checked off of the truck?
Old Jun 30, 2005 | 08:16 PM
EPNCSU2006's Avatar
EPNCSU2006
Well, MAP stands for manifold absolute pressure, and is a sensor for the computer. It tells the computer the manifold vacuum (pressure). It needs to be checked on the truck so that you can apply vacuum and watch the sensor output to see if it responds correctly to the applied vacuum.
Old Jul 1, 2005 | 07:27 AM
southsidej's Avatar
southsidej
Talking
Many Thanx to you and this "great site". I took a sensor off an old barnyard truck I sometimes use for parts and its working great.
Old Jul 1, 2005 | 03:25 PM
EPNCSU2006's Avatar
EPNCSU2006
Glad to hear you got it fixed!
Old Aug 29, 2005 | 11:04 AM
neoflee's Avatar
neoflee
How do you test the map sensor?
Old Aug 29, 2005 | 11:27 AM
southsidej's Avatar
southsidej
You don't test the MAP sensor. You read the codes from doing your KOEO scan. If the MAP sensor is bad the codes will tell you.
Old Aug 29, 2005 | 11:43 AM
EPNCSU2006's Avatar
EPNCSU2006
You can certainly test the MAP sensor. It outputs a frequency signal to the computer, which is easily read by a tachometer on the six cylinder scale or what I have done, is read it on a duty % scale on my digital multimeter. A haynes manual will give you the step by step procedure.
xjcamaro89
2004 - 2008 F150
463
Feb 13, 2026 05:07 AM
Alan17
Oct 13, 2013 04:07 PM
DJdemon6696
19
Nov 22, 2007 06:52 PM
Big Daddy J
1978 - 1996 Big Bronco
Sep 19, 2007 08:03 AM
ssanto
1997 - 2003 F150
Mar 12, 2007 07:46 AM
