Freaking high idle
Old May 9, 2023 | 12:02 AM
  #46
TobyB's Avatar
TobyB
If you cannot adjust the idle down with the IAC disconnected then you are still fighting a vacuum leak or the throttle body is worn out.
Could the IAC be sticking open?
that's a big air leak...
t
Old May 9, 2023 | 06:39 AM
  #47
R&RFord's Avatar
R&RFord
That is a good thought.
Old May 14, 2023 | 09:19 PM
  #48
Lt96's Avatar
Lt96
t
Hmm maybe but I do watch the percentages so it is working usually settles at 16 percent, but how would I test that its leaking ( assuming internally) as i have checked with propane ect
Also idle is now only about 200 rpm high which is a good improvement
Old May 15, 2023 | 07:07 PM
  #49
R&RFord's Avatar
R&RFord
The main problem for the IAC is crud stopping it from closing. This shouldn't be a problem on a new unit.
I would have to check but I think I have a rebuilt 4.9 throttle body in storage if you think that what you have is just worn out.
What kind of idle were you able to achieve with the IAC disconnected?
Old May 15, 2023 | 08:36 PM
  #50
Lt96's Avatar
Lt96
Idle still does not change with the iac plugged in or not so currently idles around 802-830 also noticed my tps voltage is not in spec closed is.075v wot is 4.64v.
Old May 15, 2023 | 08:53 PM
  #51
sswari's Avatar
sswari
Are you doing these test while the engine is at running temp, if it is not going into closed loop, than the IAC plugged or unplugged will make no difference.
Old May 15, 2023 | 09:24 PM
  #52
Lt96's Avatar
Lt96
Well finally solved the problem, turns out it was the new iac valve. On a whim put the original back on to see if the iac percentage changes and wham perfect idle ,runs like crap when I unplug exactly like it should. So I now idle at 700 rpm at operating temp . Thankyou for all the help I can only assume that in the beginning there was a vacuum leak and once I repaired that I was chasing my tail due to bad brand new iac
Old May 15, 2023 | 11:01 PM
  #53
sswari's Avatar
sswari
Glad you got it figured out!!!!
And this is exactly why we tell so many people to not just throw $$$$ at parts they THINK might solve the problems. Today's replacement parts are not nearly as well built or QCd as in the good old days.
I had to learn this the hard way, but at least I did it with Junk Yard Parts, so it didn't hurt too badly.
Kyleb123
17
Jan 27, 2023 09:16 PM
evan_nugget
17
Dec 19, 2017 07:22 PM
sandymane
322
Mar 24, 2017 07:36 PM
mr.fordneck
Jan 22, 2012 10:53 AM
MonatheGrona94
Oct 10, 2008 11:13 AM
