1985 F250-Speedometer issue
Old May 1, 2023 | 10:52 AM
fisker's Avatar
fisker
4wd Low
Hello: I have been having issues with my speedometer not showing the correct speed, I drove the truck on a trip a couple weeks ago and it all of suddenly pegged and started making noise occasionally and jumps up and down at times, I would like to pull it out and get it rebuilt is there any one who could suggest a shop that works on these speedometers that could rebuilt it for me.
Thank You!!
Mark
Old May 1, 2023 | 11:58 AM
FuzzFace2's Avatar
FuzzFace2
Are you sure it is the gauge and not the speedo cable?
If the cable needs lube it can hang up and then release and make the gauge freak and jump up high then back down over and over.
I dont know of anyone that dose that.
What you may want to try is getting one off Ebay and swapping your mileage to it.
Also try Hemmings Motor News as I am sure they would list a place that dose this type of work on older gauges.
Keep us posted what you find.
Dave ----
Old May 1, 2023 | 07:14 PM
whisler's Avatar
whisler
Is it 4x4? If so, check the nut that holds the rear yoke to the output shaft. Mine was loose and caused the speedo. to jump al over the place.
Old May 3, 2023 | 09:03 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Also try Hemmings Motor News as I am sure they would list a place that does this type of work on older gauges.
Speedometer repair listed in the 'Services Offered' section of Hemming's Motor News.
Old May 4, 2023 | 08:46 AM
WHMaintance's Avatar
WHMaintance
I have a 1985 f250 4wd i am on my second speedo drive gear. i will be replacing it for the second time in as many years. this time i intend to replace the cable as well. i think drag from the worn out cable is causing accelerated gear ware. hope this helps.
Old May 4, 2023 | 09:23 AM
fisker's Avatar
fisker
4wd Low
Appreciate the responses, mine is a 4x4 as well, I decided to get a new cable and see what happens, the noise I'm getting is from the speedometer its a whining noise that comes and goes, I will post back what happens after I install the new cable.
Old May 5, 2023 | 08:03 AM
WHMaintance
if yours is like mine it has a borg warner 1345 transfer case. sounds like your speedo has had the previous owner might have used the wrong lubricant at the speedo. i use dry graphite. it dosent attract dust. hope this helps.
Old Jul 21, 2023 | 10:36 AM
fisker's Avatar
fisker
4wd Low
Installed the new cable and still had the issue, found a used speedometer and everything works well now.
Old Jul 21, 2023 | 04:07 PM
FuzzFace2's Avatar
FuzzFace2
Thanks for letting us know what your fix was
Dave ----
MB1776
May 11, 2023 08:45 PM
Meridian_Mike
Jan 18, 2019 02:19 PM
I-6 Power
Nov 28, 2012 07:51 AM
racerx6466
Jan 12, 2012 12:37 PM
Mexray
1978 - 1996 Big Bronco
Apr 11, 2002 02:02 AM
