Fan Shroud Project
Old Apr 30, 2023 | 02:32 PM
Pokee's Avatar
Pokee
Fan Shroud Project
Decided to build a fan shroud/finger guard. Did not affect the temperature at all so I call it a finger guard.
Old Apr 30, 2023 | 03:38 PM
pineconeford's Avatar
pineconeford
Knuckle Bandage Sales Rep
Wow, that came out nice.
For the 10-fingered folks who want to stay that way........for six bucks this would match nicely.
https://www.ebay.com/itm/33484700407...Bk9SR5a5kb76YQ
Tom
Old Apr 30, 2023 | 04:01 PM
mOROTBREATH's Avatar
mOROTBREATH
I would love to have as much skill and creativity as you. I've never worked with fiberglass but I can find 100 things I'd do with it if i could.
Old Apr 30, 2023 | 04:24 PM
Pokee's Avatar
Pokee
This was my time working with fiberglass, thought I would go for it
Old Apr 30, 2023 | 06:32 PM
artscott61's Avatar
artscott61
Veteran: Navy
Very good job. !!!!!!!!!
Old Apr 30, 2023 | 06:40 PM
56panelford's Avatar
56panelford
Man that turned out really nice, great job..
Old Apr 30, 2023 | 07:26 PM
GLR's Avatar
GLR
Nice job
Old Apr 30, 2023 | 08:59 PM
Scotty's 52 F3's Avatar
Scotty's 52 F3
Nice! Any more details on your process? The foam and where you got it? The release agent or whatever your used to keep it from sticking? I'll be needing to build a custom shroud for one of my projects.
Old Apr 30, 2023 | 09:42 PM
Pokee's Avatar
Pokee
The foam is just 2 pieces of 2" pink foam board glued together from home depot that I had. I got the fiberglass supplies from HD also. 4" depth is what I needed. I had some card stock from picture framing used for the base and curved center section. I covered it all first with 2" clear packing tape. The tape acts as release agent and protects the foam from being eating by the resin. I hot glued the foam down to the card stock and glued the piece of card stock to the inside curve. The flanges I made extra wide then trimmed to fit when later. I layer one layer of cloth, one layer of matt then one more layer of cloth. The flanges I used to layers of cloth to make them thick. I used pain stir sticks covered with tape as a form for outside edges of flange as a guide for flange thickness. Sanded fiberglass, smoothed it with body filler, sanded and painted. Trimmed flanges down first.
Old Apr 30, 2023 | 11:07 PM
Scotty's 52 F3
Thanks for the info. I would have never thought you could use packing tape. I probably would have got suckered into buying special fiberglass products I obviously don't need. The only fiberglass work I have done was on an old boat of mine. I might try this instead of aluminum or steel on my non Ford project. It needs a "unique" shroud. Thanks for posting.
Scott
Old May 1, 2023 | 04:09 PM
FuzzFace2's Avatar
FuzzFace2
Nice job I just dont like the after affect of working with fiber glass
If you wanted it to help with temp the fan has to be no more than half in or out of the shroud and the tips about 1" from the shroud edge for motor movement.
It looks like the fan is a little farther from the shroud edge and maybe in to far?
Also the bottom is open still yes? If so would need to be closed up.
Just saying but yours you will keep your finger on your hands
There is a Youtube video of a guy making one from sheet metal for a stock car race car that looks easy to do at home.
Dave ----
Old May 1, 2023 | 04:40 PM
Pokee's Avatar
Pokee
Temperature runs 184 degrees even when it was 88 degrees out the other day. That works for me, and that is a hot day where I live. Usually in the 60s to70s in the summer.
Old May 2, 2023 | 07:30 AM
FuzzFace2's Avatar
FuzzFace2
That's good I just figured if someone searched for fan shroud and came across your home made one may want to know what needs to happen with fan to shroud measurements to keep their ride cool.
Dave ----
Old May 2, 2023 | 05:21 PM
acl9865's Avatar
acl9865
Pretty simple part to 3D print as well! Either as a mold or a finished part.
OCDRESTO
1947 and Older Ford Trucks
15
Nov 15, 2017 07:36 AM
ihcc104
Aug 21, 2016 08:58 AM
Ibuildmyown
15
Feb 6, 2015 09:05 PM
PRIMERED79 SHORT BED
Aug 9, 2012 09:57 PM
Sgt93
6.7L Power Stroke Diesel
May 16, 2011 01:23 PM
