Sponsored by: Real Truck
Sizing spring clamps
Old Apr 28, 2023 | 07:54 AM
kurthb's Avatar
kurthb
Replacing the worm gear clamp on the radiator hose with spring clamps, back to the way it originally. The question is what size, the diameter of the hose is 2.2" but I assume I size the clamp to the diameter of radiator outlet?
Old Apr 29, 2023 | 11:31 AM
WWR's Avatar
WWR
Good question! I actually don't know but please let us know what you come up with.
Old Apr 29, 2023 | 04:02 PM
DBGrif91's Avatar
DBGrif91
The spring type clamps (aka constant tension clamps) are sized similarly to worm drive clamps - they have a range of effective clamping diameter for a given size of clamp.
The size of the hose should be about in the middle of the clamping range. Example - if the hose OD is 2.0 inches, you’d need a clamp with a range of at least 1.75 to 2.25 inches.
EQCMCAT
Nov 3, 2017 05:51 PM
The Masked Rider
13
May 13, 2014 05:34 PM
zak8tac
29
Jun 4, 2012 03:06 PM
john19999
Nov 29, 2010 01:33 PM
gmitchell
Jan 28, 2007 06:37 PM
