2005 Psd
[i]I found out that starting in 05 SD's will only be available in CA with the Torqueshift due to emissions. Ford is also aware that the lower radiator hose can/will rub on the steering box and they recommended tying it off with wire ties in order to keep it away from the steering box until a change can be made.
[/B]
[/B]
Is this fix needed on the Excursion also?
i just found this info on the current 6.0.
The 6.0-liter Power Stroke® V-8 is a direct-injection, 32-valve turbodiesel with cast-iron block and cylinder heads. Featuring innovative Electronic Variable Response Turbocharging (EVRT), hydraulic rail fuel injection, pilot injection, and exhaust-gas recirculation, the 6.0-liter Power Stroke® boasts the highest torque and horsepower in its class.
