Battery tray for driver side
Old Apr 26, 2023 | 09:29 AM
bwguardian's Avatar
bwguardian
Looking to see what year, make, and model of other vehicles have a metal battery tray...like the one on the passenger side...for the driver side that will bolt up. I've been looking for the ones out of the OBS in wrecking yards with no success. This would be for the newer 99-03 style Superduty with the 7.3L to replace the covered plastic unit. I know the oem plastic unit can be cut down to work...I may do that on one truck...but wanting to keep one intact on the shelf...
Old Apr 26, 2023 | 09:39 AM
CousinCarl's Avatar
CousinCarl
I got mine from Rifraff, new.
Old Apr 26, 2023 | 09:44 AM
S-squatch's Avatar
S-squatch
F81Z-10732-AB
Old Apr 26, 2023 | 10:24 AM
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
Metal tray from Riffraff is linked below.
Link: https://www.riffraffdiesel.com/batte...y-driver-side/
Old Apr 26, 2023 | 11:40 AM
callforfire's Avatar
callforfire
I've been using a passenger side tray I got from a pick-n-save. It fits and it works, just that the hold down is on the back side of the battery.
If I had known Riffraff had a better option, I likely would have gone with that. It's not the first time I've done something only to find out later riffraff has it.
One of these days I'm going to have to go through their entire 7.3 relevant inventory and fully flesh out the wish list.
Old Apr 26, 2023 | 12:16 PM
A Guy In Town's Avatar
A Guy In Town
I have a 2022 F250 SD 6.2L Gas V8 and I also want to add a second battery to the driver side under the hood. Wouldn't it be NICE if Ford was forward thinking enough to design such a part and make it available?
Joe
Old Apr 26, 2023 | 12:38 PM
bwguardian's Avatar
bwguardian
I need to look at my batteries at the base to see how that might work. So did that tray arrangement cause any issues with the battery +- posts and/or cables being in the original configuration?
Old Apr 26, 2023 | 01:29 PM
callforfire
The Battery bases have all been symmetrical, meaning I've had no issues. Orientation remains unchanged.
I didn't even drill any new holes.
There is one spot I could have drilled in the tray but never got around to it. Circled in red.
The little J-nuts were already there from the plastic box. I don't recall using any additional hardware, but it has been a while since then (2014).
Old Apr 26, 2023 | 01:37 PM
bwguardian's Avatar
bwguardian
I'm thinking all batteries have the same bases on both sides...meaning they can be mounted and/or bolted down either front (side with the +- posts) or back (side opposite the +- posts)...
wedge542
Jun 22, 2017 09:38 AM
Pinky Demon
Modular V10 (6.8l)
Jan 14, 2013 09:48 PM
frankenstein
20
Feb 8, 2007 05:35 PM
69slow
Apr 4, 2003 09:39 AM
