Sponsored by: Auxito
Loose steering problem
Old Apr 25, 2023 | 11:02 PM
LD-FTW's Avatar
LD-FTW
Trailering
I've got a 99 f250 LD, 5.4, 4wd and can't figure out why I have this like dead zone in my steering. It's only when I turn the wheel (either direction), it doesn't center back up. I have to give it a small correction and it kinda jerks. I've replaced literally everything in the steering. Inner and outer tie rods, idler arm, pitman arm, steering gear box, upper and lower ball joints, end links, hub bearings. I've also had an alignment after all of this. It tracks straight, doesn't pull.
I wasn't replacing parts trying to fix the problem, just trying to freshen things up on the ol girl. Any help would be appreciated!
Old Apr 26, 2023 | 01:23 AM
Jon Freeman's Avatar
Jon Freeman
When did the steering problem start... before or after all the new parts ? Is the power steering pump working correctly....full of fluid ?
Even though it's off , does the steering wheel always return to the exact same position...or does it return to different positions randomly ?
Old Apr 26, 2023 | 08:57 AM
manicmechanic007's Avatar
manicmechanic007
The new or reman steering gear is a bit too tight? (Real common)
The caster angle is what helps to return the steering to straight
Hate to say it but the control valve in the steering gear can get ever so slightly loose and cause your touchy feel? issue
Ised to get that complaint once in a while on Lincolns et al.
Most noticable on a freeway on ramp or a parking garage circular exit
Fixed a few by replacing the thousand-dollar control valve in the gear
It comes as an assembly from Ford with the power piston and all the ***** assembled
Good luck
hope it is just an adjustment
Try backing off the sector shaft adjustment 1/4 turn and road test it again
007
That control valve feel is normal IMO, but you know those Lincoln owners
Old Apr 26, 2023 | 10:16 AM
LD-FTW's Avatar
LD-FTW
Trailering
It started after Something let loose about a month ago while I was driving and it had this pull to the right out of nowhere. Got it home and found left front hub was bad, as well as the lower ball joint. That's when I decided to just replace it all since most of it was still original.
Power steering pump seems to be working correctly and it is full of fresh fluid.
The wheel returns to about 90% of straight in either direction, depending on which way I'm turning.
Old Apr 26, 2023 | 10:20 AM
LD-FTW's Avatar
LD-FTW
Trailering
Good luck
007
Not sure if it's a bit too tight, it was tighter than the original but not difficult to turn when I was lining it up prior to install. I'll try that adjustment you suggested and see what happens, thanks!
Old Apr 27, 2023 | 02:20 PM
Jon Freeman
That doesn't sound like an alignment problem. Seems the problem is somewhere in the steering mechanism.
Old Apr 28, 2023 | 08:33 AM
manicmechanic007
If you ever get one of those steering gears apart, you inspect the sector shaft, it should have a smooth radius and no burrs
The ones I have seen that have your issue have burrs and are not all that smooth
IMO that comes from having the sector shaft adjustment too tight and driving it around that way
If you have ever seen brake pads that have been ran real hot and hard, they have curled up edges of pad material
The sector shafts get to looking just like that when they have been abused
You can massage them and save 140 bucks for a new one on a rebuild if you know how and where to
007
Jigsawman
Apr 4, 2022 11:30 AM
mikerans
Jan 8, 2012 03:05 PM
lari250
Nov 28, 2010 06:05 AM
bigorangenation
Jul 16, 2004 01:21 PM
Boss_358
1978 - 1996 Big Bronco
May 10, 2001 05:57 AM
