Steering questions
Old Apr 3, 2022 | 12:47 PM
Jigsawman's Avatar
Jigsawman
Steering questions
Ok, now I am on to steering stuff. The steering in the 78 F250 4x4 was pretty sloppy. A mechanic friend of mine suggested that the drag link was worn out. He said it looked like it moved around too much. I also searched the forums here and found that the gear box likely needed some adjustment as well. Here are my steering issues:
1. Whoever owned this last put a lift kit on the truck which included a drag link to accommodate the lift. In doing so, I am pretty sure they did not have the steering pitman arm lined up correctly because the truck turns on a dime to the right, but a left turn is almost a three point turn to accomplish (sigh).
2. They replaced the steering wheel and it almost feels like there is something not quite tight on the upper end of the steering column, almost like a worn bearing feel to it just under the turn signal package. Can't find a break down image of the steering column to know what the issue might be (not that an image would be the answer anyway).
3. In regards to the drag link, what is normal play on those?
4. I loosed the adjuster screw and nut on the steering gear box and turned the screw in about one turn. Steering feels a little better but still not 100% right.'
Any insights form you guys would be helpful. You always seen to get me on track quickly. Thanks!
JSM
Old Apr 3, 2022 | 02:04 PM
ranger140892's Avatar
ranger140892
Grumpy goat
First thing, "adjusting" the steering gearbox is a No-Go. If it has deflection, it needs to be replaced. And a parts store remanufactured steering gearbox will have new seals, but just as much deflection as it had when the remanufacturer received it. It's expensive, but look into Redhead or Blue Top steering gear boxes.
As for the drag link ball stud, it should be rigid enough that you cannot move it with a sharp smack from a rubber mallet. Beyond that, check the gearbox box bolts for torque, frame integrity where the gearbox attaches, tie rod ball studs, ball joints, wheel bearings, and spring bushings. All of those can give similar symptoms. Also, check out your lower steering shaft, and upper steering shaft for deflection.
Old Apr 3, 2022 | 02:08 PM
tbear853's Avatar
tbear853
JSM
When "whomever" lifted the truck, they increased the included angles of the short drag link to ball joint studs, and putting a not straight but S shaped drag link in place does not correct them, they should have used a drop pitman arm on to correct the angles. By doing it as they did, they swung the axle end of the drag link down, which swinging it through an arc, moved it more forward too. Result was they then had to hold the steering wheel to the left to actually go straight then. Now when steering left to make that U-turn, you run out of travel. and the lost travel is in the turn to the right now so why you see the quick sharp right turns you spoke of.
How to fix ... either return ride height to stock and get a new stock drag link ... or ... get a pitman arm intended for a '78 F-250 4x4 with the lift built in it as an offset to re-align the drag link, and you'll still need a new drag link for a stock truck to maintain end ball type joint clearances so they don't bind. The S shaped one you might have only gave clearance for those two included ball jointed ends after the pitman arm was raised further above the spindle end.
Old Apr 3, 2022 | 06:35 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
That screw on the steering box is NOT an adjuster to take up the slack for worn parts. That screw is for setting the preload on the input shaft AND THAT IS IT. You get it set wrong you can accelerate the wearing out of the internals (I bet they are already worn out) of the steering box and worse case cause it to lock up in a turn.
How much lift does it have? With a 4" and up lift kit you for sure need a "drop" pitman arm and an adjustable steering link. Item #4 in tbears diagram.
Drag link should be tight like tie rod ends. I bet your steering box is worn out, start your insp there and work your way to and thru the steering linkage and the tie rod ends and the end compartment steering shaft. Insp the bell end (where the steering shaft connect to the steering box input shaft) and the u joint in the shaft where it connects to the steering column coming out the fire wall.
Then read up on Borgeson steering shafts. https://www.borgeson.com/shafting.html
I know I posted some steering column diagrams here. https://www.ford-trucks.com/forums/1...then-some.html
Old Apr 3, 2022 | 07:12 PM
diesel rookie's Avatar
diesel rookie
X 2 on the Red Head or Blue Top. If you plan on keeping this truck you may want to check into the crossover steering setups. Before spending $$$ on the stock setup.
Old Apr 4, 2022 | 09:54 AM
fordrealdrive's Avatar
fordrealdrive
Deleted...
Old Apr 4, 2022 | 10:20 AM
tbear853's Avatar
tbear853
Originally Posted by fordrealdrive
... etc ... The turns easier one way versus the other is a steering box issue & can happen on any vehicle ... etc ...
As I read it, it's not effort he was describing or complaining of, ... rather ... it was only how tightly (turn radius) it would not turn left or would turn right "of center" to the stops.
Old Apr 4, 2022 | 11:30 AM
fordrealdrive
Deleted...
GroovChampion
May 21, 2017 09:32 AM
82airborne82
Oct 13, 2010 05:04 AM
cc322
Jun 24, 2010 08:46 PM
rogue_nine_2000
Mar 20, 2005 03:28 PM
1995Ford250
Jan 20, 2005 12:35 PM
