Any safe diesel stabilizing solution
Old Apr 24, 2023 | 10:49 AM
Rtgebm's Avatar
Rtgebm
I have a 2005 6.0 ambulance. I'm going to be rebuilding it as a camper/overlander so it will be sitting for months. All mechanicals are already done and it runs great. I will start it often and keep it going that way but I have a nearly full tank of diesel and I may need to stabilize it somehow since I probably can't use it before it goes bad. Is there an actual safe for my 6.0 something - like sta-bil for diesel or diesel kleen I should use to keep the diesel ok for months? I have seen a lot of discussions (I know it was discussed 100 times) but don't have a clear solution or answer. I don't want to mess with it as it is perfect as it sits.
Old Apr 24, 2023 | 12:08 PM
wpg_250's Avatar
wpg_250
I'd imagine something from Lucas or Archoil would fit the bill and if in doubt just double dose that sh!#
Old Apr 24, 2023 | 03:01 PM
diesel_dan's Avatar
diesel_dan
I use Diesel Kleen, but mainly for lubricity. I have several diesel rigs that sit for long periods between use and they all start and run fine whenever I do use them. Count me as either ignorant of the need for a diesel conditioner or lucky - our climate is pretty mild. Let's see what some of the others hear have to say...
Old Apr 24, 2023 | 03:06 PM
bismic's Avatar
bismic
I purchased some Power Service Clear Diesel after doing a bit of research. Used it once, but the diesel I used it on went into a tractor!
Old Apr 24, 2023 | 05:43 PM
runthatjunk's Avatar
runthatjunk
As long as it's not biodiesel it will be fine.
Old Apr 24, 2023 | 08:05 PM
Rtgebm's Avatar
Rtgebm
Sounds like I probably don't need anything, really. i guess it isn't e-10... Thank you for the info.
Old Apr 25, 2023 | 09:15 AM
knottyrope's Avatar
knottyrope
old non ethanol fuel, starts up fine even after 7 years if lid was kept tight
in warmer climates, algae can build up if you have some water in the tank
My KDX starts in 2 kicks since 1991 and I never drain the plastic tank. Started up fine after sitting 5 years when I blew my knee out.
Old May 1, 2023 | 12:01 PM
MisterCMK's Avatar
MisterCMK
I put fuel in mine last fall. It sat almost 6 months and was just fine this spring when I took the pickup out again. I think it was even B10.
I wouldn't worry too much about it.
This is in MN as well where we have winter.
Old May 7, 2023 | 12:21 PM
HT32BSX115's Avatar
HT32BSX115
I think your main problem letting it sit and only starting it up once in a while will be the turbocharger variable vane system getting sticky/stuck.
Fuel in a tank takes a lot longer than several months to become a problem unless you live in the norther tier (cold) country and you put it away with "summer" fuel and then try to run it in the dead of winter.
Cheers,
Rick
Old May 7, 2023 | 12:24 PM
Thealien's Avatar
Thealien
I do not have a diesel, but look into this. I have been happy with their gasoline, fuel stabilizer for a decade.
you can buy it everywhere including Amazon by the quart.
https://priproducts.com/wp-content/u...9/11/PRI-D.pdf
Old May 7, 2023 | 03:23 PM
Toreador_Diesel's Avatar
Toreador_Diesel
FTE Leadership Emeritus
A double dose of Hot Shot EDT should do nicely. It helps diesel stay fresh and improves the quality of it for some time.
relayman53
Apr 30, 2014 12:01 PM
DCD1019
Louisiana Chapter
Jan 27, 2012 03:29 PM
Fomoko1
17
Dec 13, 2007 07:29 PM
powerstroke6ltr
Jul 11, 2005 08:07 PM
wilba504
Jul 29, 2004 12:35 PM
