View Poll Results: Any others having this issue
Tricks of the trade
0%
Reference web site utube
0%
Multiple Choice Poll. Voters: 0. You may not vote on this poll
Distributor frustration
Old Apr 23, 2023 | 04:35 PM
Bill's F250's Avatar
Bill's F250
5th Gear
I'm struggling getting a new distributor installed. 1979 351M F250.
Top dead center no problem. The oil pump shaft is not centered so the last inch will not drop in. Any suggestions
Thanks
Old Apr 23, 2023 | 05:33 PM
Mark8man's Avatar
Mark8man
Assuming its not sliding down onto the pump shaft, take a 1/4" drive 5/16 socket and tape it to a long extension. Slip it onto the oil pump shaft hex and rotate it a little at a time, like a 1/4 turn until the distributor drops in where you want it.
Old Apr 23, 2023 | 08:03 PM
1browski's Avatar
1browski
I dont know how it is on a 351 but Ive had issues here and there on the FE motors. There is like a sealing ring at the top and an O-ring lower down the shaft. Sometimes the lower one is either too big or hard and the dizzy wont drop that last little bit. Ive changed that before and had it drop right in after that. That just happened to me about 3 or 4 weeks ago. I was stabbing that thing for an hour straight and pissed off before I got it in there. I was switching back to my original dist from an HEI and adding petronix to it. Good luck.
Old Apr 23, 2023 | 08:15 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
If the oil pump shaft is not staying/standing up straight (centered) glob some Vaseline or grease down in the hole around it and use that to hold the shaft straight up/vertical.
Old Apr 23, 2023 | 08:45 PM
jtrux's Avatar
jtrux
Personally I don't worry about where the rotor lands. Wherever it is pointed is where I start stabbing plug wires.
Old Apr 23, 2023 | 10:42 PM
cwegga's Avatar
cwegga
I had to do this a bit ago when I put a new distributor in my 400. I thought the shaft was off center, but I think the hex on the new distributor was just clocked slightly differently than the old one. I rigged up a socket etc. so it couldn't fall in and turned the oil pump drive a tiny bit at a time and tried to restab each time. After the 5th time or so it went in all the way.
Old Apr 24, 2023 | 05:25 AM
Bill's F250
5th Gear
Thanks to all I will try again. Slowed down because the parts house gave me the wrong intake gaskets
Old Apr 24, 2023 | 06:20 AM
egchewy's Avatar
egchewy
put a little downward pressure and bump the starter. It'll drop in.
Old Apr 24, 2023 | 09:50 AM
beartracks's Avatar
beartracks
I usually take a counter sink bit and ream out the inside of the dizzy shaft a little bit.Not too much. It helps a lot.
BmorePhotog
35
Jan 14, 2023 12:03 PM
CaptainJRS
13
Oct 24, 2021 12:03 PM
MShepherd2
Jan 21, 2018 06:36 AM
lalberts
Dec 4, 2016 10:30 PM
grizz3000
Aug 7, 2007 10:22 PM
