I finally found a nice well built 5.0 roller engine for my 1978 F100. I see that alot of people convert to the 1978 model 302 oil pan but I am wondering if thi sis mandatory or just an option many go with because of the oil dripping on the susension from front plug etc.
When looking under the truck it appears there is plenty of room for clearance.
Reason I am asking is because this is a nice engine with no leaks and i would prefer not to mess with changing the pan if it is not necessary.
What year is the 302 you are putting in and what did it come out of? If you have clearance it should work.
It is an 89 out of a Mustang....Looking at the factory 302 int he truck their is a ton of clearance already with the 78 pan so that shouldn't be an issue
The rear oil pan drain may end up above your crossmember.
I had read someone mentioning the crossmember but thought they said the front plug might drain on that....I am gonna check dimensions though I hadn't considered the rear drain plug. That would be a mess. LOL
How many miles on the engine? Has it been sitting or was it being regularly ran so the gaskets stayed wet?
It's the old "Ounce of prevention is worth a pound of cure vs. if it ain't broke don't touch it" argument. I prefer to reseal an engine I'm swapping in just as cheap insurance. It's also a good time to clean up and paint everything. If the gaskets are in good condition it might stay dry forever or it could start leaking in a couple month if they're old, dried up, or if a cover/pan took a whack removing/moving it and broke the seal. Would you rather take the time to put in new gaskets and seals now while it's all easily accessible, or maybe end up with leaks shortly after and have to deal with it in/under the truck?
That's the thing, the engine has maybe 5-6k mile son it since last build, it is already painted and all the gaskets and hardware inside were done at build with high quality stuff.I also saw it running on an engine stand so it has't been sitting around unused for a while. Hence my not wanting to "fix what isn't broken" lol
I really am not worried about the gaskets leakign or anything...My only wonder now is if the rear drain plug clears the crossmember..I guess I will find out soon enough LOL
