I'm getting a 552 code in the KOEO test.
552 is Thermactor air bypass solenoid circuit fault
What solenoid is this? where is it located?
Is it a TAD or TAB solenoid or something else in a different location?
If I can nail down what solenoid it is I can start tracing electrical and vacuum lines from that location.
The electrical connector "key way" is centered on a TAB solenoid, it's off to one side on the TAD solenoid. They're mounted side by side, on the driver's side of the engine.
On the back of your engine, the green dot is where the vacuum line from the TAB solenoid should connect. The red dot is where the vacuum line from the TAD solenoid should connect.
