552 code help
Old Apr 22, 2023 | 08:28 AM
yeet's Avatar
yeet
552 code help
I'm getting a 552 code in the KOEO test.
552 is Thermactor air bypass solenoid circuit fault
What solenoid is this? where is it located?
Is it a TAD or TAB solenoid or something else in a different location?
If I can nail down what solenoid it is I can start tracing electrical and vacuum lines from that location.
Thanks, Jeff
Old Apr 22, 2023 | 09:20 AM
Soup bean's Avatar
Soup bean
The electrical connector "key way" is centered on a TAB solenoid, it's off to one side on the TAD solenoid. They're mounted side by side, on the driver's side of the engine.
Old Apr 22, 2023 | 09:35 AM
Soup bean's Avatar
Soup bean
On the back of your engine, the green dot is where the vacuum line from the TAB solenoid should connect. The red dot is where the vacuum line from the TAD solenoid should connect.
Old Apr 22, 2023 | 09:39 AM
yeet's Avatar
yeet
Perfect. Thank you! I've got new vacuum lines and assorted T's. Finally ready to tackle this thing today.
Old Apr 22, 2023 | 10:08 AM
Soup bean's Avatar
Soup bean
Hoping to start mine on my next days off.
Old Apr 22, 2023 | 10:53 AM
yeet's Avatar
yeet
Good luck soupbean. I'm hoping that taking care of the KOEO 552 issue will also take care of the KOER 311 code I'm having.
farmer4
Oct 23, 2012 07:22 PM
89Tone
Aug 3, 2005 08:53 AM
weasel_2004
Aug 5, 2004 06:49 PM
joycat1
Modular V8 (4.6L, 5.4L)
Jan 26, 2004 12:02 AM
