Ignition Switch
Old Apr 20, 2023 | 12:30 PM
bass-n-fire's Avatar
bass-n-fire
Ignition Switch
I just replaced the ignition tumbler in an ‘83 that I purchased. I replaced it because they couldn’t find the key. After replacing the tumbler, I noticed there is no “return” from the start position. Like a spring is missing. Where do I need to look to isolate the problem?
Old Apr 20, 2023 | 02:55 PM
My4Fordtrucks's Avatar
My4Fordtrucks
The “return” function is in the ignition switch.
Old Apr 20, 2023 | 03:59 PM
FuzzFace2's Avatar
FuzzFace2
And that is down at the bottom of the column on top of the tube.
When you turn the key is moves a rack & pinon that pushes a rod.
This rod is bent to a 90* on the end and fits into the switch.
The switch is held to the column with 2 screws and lifts off the rod.
Sometimes you can spray it with electrical cleaner and it will work again or get a new one.
Dave ----
Old Apr 20, 2023 | 05:33 PM
Franklin2's Avatar
Franklin2
Drown the column with wd40 when you replace the ignition switch and that will help also. Take the u-bolt bracket that holds the column off and drop the steering wheel onto the seat. Then you will see the ignition switch mounted on top of the column behind the instrument panel.
If you have a automatic MAKE SURE YOU TAKE THE SHORT COLUMN SHROUD OFF AND UNBOLT THE LITTLE PLASTIC CABLE PIECE. This has a string inside that operates the PRND21 indicator and if you break it, they are hard to find.
Old Apr 20, 2023 | 05:45 PM
manicmechanic007's Avatar
manicmechanic007
The ignition switch spring is pretty damn tough and the problem is most likely a gummed-up rack and gear that actuate the rod to the switch
You might want to clean all the old grease and gunk out, and re lube the rack and gear
Replace the ignition switch just for GP's
Old Apr 20, 2023 | 05:52 PM
JimsRebel's Avatar
JimsRebel
Do you have a tilt wheel?
Old Apr 21, 2023 | 07:34 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
1978/91 F100/350, Bronco & Econoline: Tilt wheel operates by pushing the turn signal handle forward.
Bigdukesix
Feb 16, 2021 07:32 PM
n3hcp
6.7L Power Stroke Diesel
Sep 19, 2014 06:19 PM
mark8881
1997 - 2003 F150
Oct 19, 2008 02:10 PM
rickj000
Aug 7, 2004 05:50 PM
